Weird electrical issue...alternator?
George Owens
Ok so I’m gonna start working on this issue tomorrow but here’s what happened driving down the high way and the TPMS starts blinking again along with the airbag light. ( out of nowhere)So then I roll the windows up then a slight stall happened, airbag light, radio start skipping,lights were flickering , the radio clock reset, it was pretty scary going 60mph but i suspect the alternator but what are other possibilities? (08 tahoe LT)
P.s no charging system warning
RED TAHOE LS
Rossville, Georgia USA
When voltage drops below 9 volts, weird things happen in the cluster, even the tachometer will go nuts. Is your battery light ON while running ? An alternator must have good battery voltage to charge like it should. Like previous post suggested, go to Autozone, O'reilly, walmart, for free testing. good luck.
David g.
George Owens
George Owens
Probably the battery, but start checking the battery cables and then the grounds. Didn't you do some recent work on it George that you posted?
Only work I did recently was update the headlight and fog bulbs to white leds... other than that not that I can remember, I changed the sparkplugs and wires a while back last year
George Owens
George Owens
David g.
No,when this happened the light lit up, but went away when it started to act normal, the plan today is to take both the alternator and battery to Autozone today and have them check both 3 times, my Monte Carlo alternator went bad and tested fine the first time, I told them to check it 3 times and it failed 1 of 3
George Owens
George Owens
Sounds like battery cable ground, start there as james said.
I just saw a vid on YouTube where similar things were happening, he said his was the negative ground, now would I change the negative terminal or??
PG01
Up here to the right
Very easy, unbolt from battery follow cable to where it goes and unbolt it there. Take to auto parts store and get same length.
George Owens
George Owens
From what I hear this one Cable has three different points to where it’s grounded and supposedly it has a sensor
George Owens
George Owens
Quick update took the battery to AutoZone and it tested good at 94% have to take the alternator and put it back on the car because that’s the only way they can test it
George Owens
George Owens
OK before I put the battery and alternator back on I scrub them clean with wire brush, I scrub the terminals and I scrub the battery post. I also scrubbed the post and terminals that connect to make a fuse. Went to AutoZone and the alternator tested good. So I’m a little bit stumped trying to see if I can make the issue happen again currently
kbuskill
NE. FL.
Internally corroded battery cables are the culprit more often then not.
George Owens
George Owens
I hear that a lot especially the negative ones, I’m gonna look into ordering one, the dealership wants 170 for one
George Owens
George Owens
Plug the part # you got into google I guarantee youll find it cheaper..try amazon 1st
Got it for 48 bucks rockauto, now I’m tryna find out how to install i seethe 2nd ground but the 3rd seems to be under the coolant hose might give me problems
schafer98
