Oil Pressure Low Stop Engine (replaced sensor)
David Smith
Savannah, GA
Also, does anyone know the specific torque specs for the oil pan bolts, pick up tube bolts and the flange bolt on the pick up tube?
kbuskill
NE. FL.
Going to grab a new pan gasket and the new o ring. I will be installing after I get off work today. Do I need to use loctite on any bolts?
No loctite but you will need some RTV for the corners of the pan.
Oil pan bolts
To engine and front cover 18 ft-lbs
To rear cover 106 in-lbs
To bellhousing, converter cover and transmission 37 ft-lbs
Transmission to oil pan bolts 37 ft-lbs
Not 100% sure on pickup tube torque specs as its not listed in my book.
Maybe @swathdiver Will chime in.
David Smith
Savannah, GA
Oil pan bolts
I need RTV in addition to the pan gasket? Should I just put a bead all the way around, or just in the corners?
kbuskill
NE. FL.
You only need a bead about an inch long where the timing cover and engine block meet the oil pan up front and the same in the rear where the rear main seal housing cover and block meet the oil pan.
David Smith
Savannah, GA
That makes sense. I will pick up a small tube today as well
David Smith
Savannah, GA
Does the RTV just go on the oil pan on top of the new gasket where the front cover and rear cover meet the block?
LanceD
AZ
Not sure if anyone has mentioned it but there are 2 different O ring sizes, make sure you use the correct one.
The pickup tube for the transmission is press fit, no nut/bolt. The bracket on the tube that secures it via a bell housing bolt is 37 ft lbs like the others.
kbuskill
NE. FL.
Aside from waiting until I have the old one off lol. Show online that it ''Fits My Vehicle"
When I bought my HV/HP oil pump it came with 2 O-rings.... one orange and one green if I remember correctly. Or maybe 3... I vaguely remember a black one as well... but I have slept since then, so I can't be sure.
kbuskill
NE. FL.
He is looking for torque specs on the oil pump pick up tube. The bolt that secures it to the oil pump and the bolt that secures the bracket on the tube to the block.
Ohh sorry, I posted it recently... Hmm...
Ok, the bolt is 106 inch pounds (8.83 ft lbs) and for the nuts (tube to windage tray) it is 18 ft lbs. This is from the service manual for my truck.
CobraKing
Should be reddish-orange in colour. Just use some of the existing oil to lube it before sliding it on and then gently push it back into place. You'll know it's making a good seal as there's a bit of resistance. On my '14 truck the pickup line just dropped right off, the minute I undid the bolt holding the tube to the pan.
David Smith
Savannah, GA
Thanks for all the help guys.
I did the job yesterday and it works fine now.
I did end up having to drop the steering rack and pinion to get the pan out, put that was just a matter of 4 bolts.
The o-ring that I pulled out was pretty flat. It had a minimal amount of resistance when I pulled the tube out. New one went in great. Torqued the 10mm bolt to 106 inch punch with blue loctite.
Torqued all the rest of the nuts and bolts, filler her up with oil and put on a new oil filter. Fired her up and I did not see any leaks at all, and pressure was holding steady after running for 30 mins at ~35psi.
Thanks again for all the help and insight.
David Smith
Savannah, GA
That's great to hear, so can you say for certain that it was the O-ring?
Absolutely. The only other thing that I did at the same time was change the oil and oil filter. The old o-ring was kind of flat, so I am positive that was the issue.
Previously I had changed the oil pressure sensor, which did nothing.
kbuskill
NE. FL.
Not to burst your bubble, because I hope your right, but an oil filter could definitely cause the same issue.
Lots of guys on here have had low oil pressure issues and changed the filter and thought it was fixed infill the filter started getting dirty again... including myself.
It is usually accompanied by some lifter ticking.
A new oil pump and O-ring fixed mine, although my pressure never went below 25 psi on the gauge.
JamesinAbilene
