Goodinblack
I Like Tacos
Dirty South
Waxed the roof. (The lines are Chem trails)
Got this stupid plug out.
Sent from my SM-N910V using Tapatalk
Goodinblack
I Like Tacos
Dirty South
I must say although I never hated my Z71 roof rack, still what a pain. The new Escalade rack is so much easier to work around when washing and waxing. Look way more updated too.
Goodinblack
I Like Tacos
Dirty South
I dont hate mine enough yet.
I never hated mine. Was actually set to put it back on. Just found a Escalade rack and went and got it lol.
There are two rust spots that formed under mine. About the size of a sharpie point. Also one of the inserts that is in the roof that the bolts goes in rusted a bit. I painted it black then put new rack on
Shaw520
Looks good.
kwOH
Banned
Well, about 2 hrs into spindles and chill (with a dinner break) we’re basically at the same place. Lower balljoints WILL NOT let go. They’re frozen in the spindle and I don’t have a BFH or a pickle fork
F’n pickle fork......
ScottyBoy
Shreveport, La
Prob not member here, but I really like this guys tap into the oil cooler line on all his chevy's...makes things easier on trans flush day
I am leery of using those compression fittings on my truck. Not like it's super high pressure, but still....
I have done mine VERY similar. When I flush mine, I actually replace the filter and pan gasket first. Then I unhook the trans line from the radiator and connect a clear tube to it and run it to a bucket like this guy did, and then flush out the remaining fluid still in the torque converter and lines.
00'BlueSteel
Carolina
Ran into the same problem. This is what I did since the spindle gets replaced anyway and I was doing the lower ball joints as well. I took the spindle and the lower control arm off together. Laid them out on the ground so the ball joint stud is sticking up, heated the spindle right around the balljoint with a regular propane torch, sprayed the balljoint shaft with liquid freeze and immediately starting hitting the balljoint stud with a 2.5lb hammer. Couple hits it comes a part, lower control arm suffered no damage. However one would never let go, I had to cut the balljoint stud in half to separate the two pieces and pressed the left overs out of the lower control arm with a rental ball joint tool from the local auto parts store and left the stuck piece in the factory spindle. I had the ball joint tool rented since I had planned on replacing them anyway. I tried pressing the balljoint out of the spindle with a shop press and they wouldn’t let go, it bent the plate in the press that the piece sits on.
Hope you have better luck, it was a huge pain in the ass. But they will come out one way or another.
Goodinblack
I Like Tacos
Dirty South
What a pain
00'BlueSteel
Carolina
What a pain
Yeah was a massive pain, it’s one reason my rebuild took so long, we spent the better part of a night fighting that. Tried multiple different sized pickle forks, tried just heat, tried the shop press, then went to sleep got up the next day and did the heat and freeze and cut.
I know Zach has plenty of experience so he might have already gotten them out, just wanted to share the info for others and incase he is still fighting them.
04Huck
"I'd rather be lucky than good"
Buford, Ga
:shake: I appreciate the tip, that was gonna be my next step. But, with a bigger hammer, we have progress!
Escalade2007
