Anyone done side exit exhaust?
Big Mama
Virginia
Wondering if any one has done an exhaust exiting in front of the back tires on 07-14 Denali?
Big Mama
Big Mama
Virginia
Good question. I’ve seen several cars done that way and I like the look. The other option I’m considering is moving the exhaust where the muffler ends before the rear axle and the tips point down but I’m afraid of causing a highway drone.
992dr
Eastern N.C.
I haven't seen that style done on a Tahoe/Yuk before.
G-Wagons have them and it looks pretty cool but its also a dual set up on both sides. Not sure its possible seeing we have the gas tank on the drivers side.
I'd be a little weary about dumping at all in an SUV. Never mind about the drone I'd be more concerned with the Carbon Monoxide (CO) poisoning.
63Blackseries
Canada
Yeah the g wagon looks dope with it and yeah I agree exhaust fumes might be bad when windows are down. I found a random pic of a Tahoe with it in my phone.
Big Mama
Big Mama
Virginia
That’s exactly what I was looking for. I wonder if that is true dual or a dual tip. I want them to exit the same side like that but not sure I want to modify the entire exhaust. Thanks guys. Oh, and what’s a game wagon?
63Blackseries
Canada
I meant g wagon, g63 Mercedes Benz Damn auto correct! Haha
Think over time heat from the tips would distort the running boards? They are only plastic.
I would think so too
PG01
Up here to the right
So is my back bumper/quarter panel.....NNBS... i know its further back but mines about 1/4-1/2” away and no probs
The exhaust tips don't get hot, they're too far back. Go check it out next time after driving. Pretty warm, yes, but not hot.
992dr
Eastern N.C.
I meant g wagon, g63 Mercedes Benz Damn auto correct! Haha I would think so too
Here's a G Wagon :)
As for the heat, I don't think they'd heat them up but speaking from experience they "exhaust" enough heat to melt my passenger rear light harness after removing my rear muffler :)
Big Mama
Big Mama
Virginia
Good point. I thought about back seat folks getting burned. I looked for a kit and saw several from flowmaster but no videos about alterations or welding. I’d assume some hangers would need to be welded to the frame. Also didn’t see a Yukon kit.
You should take a look at where your muffler is. I believe mine's right there where you're talking about having the exit. I'm not sure if there would be room.
Big Mama
Big Mama
Virginia
my muffler is about even with my back tire. It’s a short fat little guy. Like my brother in law.
PG01
Maybe because mines a Denali and has dual exhaust all the way back to the inlet of the muffler.
I just don’t remember how far back the muffler is in relation to the wheel... technically tho, a shorter muffler like a mf 12589 will give plenty of room.... if they are looking to replace muffler also
992dr
Eastern N.C.
If you were to use the stock muffler, you could shorten the front section going into the muffler to pull it forward and then you'd have plenty of room to swing it out the side.
Or like Galante mentioned, if you go with a new shorter muffler, that would also work.
They also make bolt on hangers, no welding at all.
Big Mama
Big Mama
Virginia
Ah nice tip about bolt on hangers and shortening the muffler inlet. Thanks
Buford bubba
