Lowering a 2004 Yukon XL Denali
Wahpeton, North Dakota
What would be the best way to lower my 2004 Yukon XL Denali. Im wondering if I could just reconfigure my air ride shocks? I want to drop the front at least 3 inches and the rear about 5 inches. Is there any way to do this with out dumping alot of money into it and without jeapordizing the function of my auto ride system. Thanks in advance.
BlizzardX23
Sacramento, California
Theres about 32783784 posts about this already...check the "suspension" section for the 00-06 generation...or do a search
As for the autoride issue...no, if your going as low as 5 inches...you have to lose the autoride feature...
emay
S. Elgin, IL
Got my gear through MAX here on the forum. As Blizz stated there's plenty of threads in here to help you as well as talk about combinations of parts.
Here's a shot of mine from a few hours after I finished the install. It's settled in the rear and the thing is now level. If we could get a break from all the damn snow I'll get some more pics for this and a couple other threads on going.
Denalilama
Bay Area, CA
How is it driving with that suspension set up in the snow? Would you recommend it?
emay
S. Elgin, IL
Snow is not an issue, handles great and tracks very well.
I definately need to do the free travel mod. We had a recent plummit in temps to well below zero for about a week, I immediately noticed the rear was hitting the bump stops via audible sound in the cabin. Apparently when it's above freezing the bump stops are a bit softer and cushion the sound and feel. Once it got super cold I noticed right away audibly that the free travel mod is a necessity.
By the way, mines an 05 and it was a 2/3 kit with the rear isolators removed. As you can see it came down a bit more than 2/3.
Max
Mile High
Denver
I love my drop in the snow, just have to watch out for small children and dogs. You'll get through everything you do now as long as you have good tires.
What size of tires do you have on it. Looks great, you got the height exactly how I want mine. Ill be PM'ing you in a little while. Thanks for your help man. Take Care
---------- Post added at 04:52 PM ---------- Previous post was at 04:23 PM ----------
As for eliminating the auto ride feature does this enable the service light or do you keep everything intact and just install lowering links.
zieglerj-pdm-specialist
in 100 degree sandbox
23
I have 23" wheels on mine and Im wondering if lowering will be a problem with rubbing when turning or any other issues that come with lowering Denali's
Knobz
Santa Cruz, CA
No, you most likely will not be having rubbing issues but that also strongly depends on what wheel/offset combination you get.. If you get the correct offset you will have zero rubbing issues.. I have 26's and love it. No complaints.
2" Spacers
My problem is that I like my wheels to be outside of the wheel well at least 1" so I bought 2 inch spacers to bring them out past the wheel well and it makes it look tough. I love how the aggressive stance it has. Before Spacers no rubbing and after spacers it rubs with my 23's but not my factory rim and tires, So If anyone was going to use them for your factory wheels they work great but my 23's they rub. So Im going to need to get rid of the two inch spacers or go with a smaller tire wall. So I think Im going to have to sell the spacers but I love the look because it looks like a mean machine with the wide stance. So If you know anyone who wants 2 inch spacers for a yukon or sierra Ill let them have them for $100 and I paid $189 for them. They were used for 4 months last summer and taken off when I put my factory tires on for winter. They are in great shape and if anyone wants to make an offer Im open to that tool. Take Care
Knobz
Santa Cruz, CA
It's just the nature of lowered vehicle... Lowered/slammed your gonna want your wheels tucked inside.. Lifted yea, you can run wheel spacers an get that wide aggressive stance..
I want mine lowered and my wheels still stcking out of the wheel well. Im not going to drop it to the floor because I live in North Dakota but I do WANT TO LOWER the rig and try to keep an offset,
NORCAL SS
SUV SUSPENSION GURU
front djm keys for 1 inch
rear djm shock extenders
rear djm 3 inch springs
300 shipped and you can keep the tires out of the wells and in rear the bumpstops you can cut down so you can get most travel before tire hits the fenderlip
Escalade2007
