20" tire sizes for a 2" lowered Limited
ParacordPaul
Hey Guys,
I just lowered my Limited 2 inches and I'm looking for some opinions on 20 inch tire size. From looking at tire calculators it seems 285/50 20s are really close to the stock diameter tires I have now (255/75 16). Any opinions on the size?
Thanks,
Paul.
eatsleepdrey
waukegan, il
Hey Guys,
Thanks,
Paul.
Any insight on this post would be greatly appreciated. Im in the same boat for different reasons!
I have a 97 Tahoe 2wd 4 door, and the springs were slightly cut to even the ride height out. The car looks lowered compared to any 4wd models.
Paul, I don't mean to impose on your post, so hopefully my research up to this point will benefit you...
I have a set a of polished 20s with 275/45/20 tires ready to be replaced. I was thinking to upgrade to 275/55.... but my internet research calculations say that adds about 3 inches from factory height. I went out to the car with a 3 inch paper to size it up.
From what I can tell, my truck would potentially rub when turning with 275/55. There is maybe a 1/8 to 1/2 inch potential clearance issue. But in the back and around the wheel well it seems good to roll.
The 275/50 seem to be the next logical step. Makes sense why they are the most expensive options. I found some all terrain tires with high reviews for 118 on tire rack!!!! then i looked for 275/50 and the cheapest I would purchase were like double the price. INSANITY!
P
ParacordPaul
Hello,
After doing the research I found this size converter which helped me make my decision. https://tiresize.com/converter/ I wanted to stay with a tire that was as close in size ( diameter and width) as the original tire. My original was 255/75r 16 and I went with a 255/55r 20 which is almost exact.
Hope that helps,
Paul.
TigerEyz3
Slow and Steady
TN
I have run 275/45/20 and 295/40/20 (wanted wider) tires on my Tahoe (2" spindle drop up front) with no issues.
That said, you're a bit limited in tire manufacturers in the 295/40/20 (Toyo), but I was very happy with the handling, ride, and appearance.
juniordaboi909
