Cargo Area Light Mod
noob
New Orleans
Man, if I man up enough courage to hack into my esky, this maybe the mod I want to tackle. Functional and looks good
Rdr854
Northern VA
And here are some pics showing the lights "in action." I drove someplace almost pitch black and turned off all of the other lights in/on the car. All of the illumination is from the LEDs.
View media item 26842View media item 26841View media item 26843
It does look a little spaceship-like when you see all 10 lights at once, but that's a ground-level view. From most perspectives, the only LEDs you really see directly are the two that project out.
Fire Department chief’s/command SUV have hadn this feature for years. Just not as nicely done as yours.
RST Dana
OH
I am working on adding cargo lights, but I really like the idea of getting power from the second row dome light. Anyone have details on how I can remove it to access the power feed? Once it is finished, cargo will light when doors open, or the additional switch I have for the rear area.
73impala
Margate, FL
From what I recall you should be able to pop the clear lens off and then it kind of just slides out. There's a tab that goes under the headliner and the lens once clipped in that holds it in place.
RST Dana
OH
I have this phase complete. I’m going to add a separate rocker switch fir the rear facing eyes. 7C2AFB61-5F94-43F0-8478-B8941C09DA39.jpeg691FA3D1-4FC8-49D8-AF99-B62F4896AB31.jpegD5EE489C-0891-4C92-8505-ECCAB259F843.jpeg3183B77B-3103-4F3A-B3E9-D725FD13B5D1.jpeg 24D66A8C-7D4E-46E9-9E73-F03BFDE153C0.jpeg
73impala
Margate, FL
Here is my set up so far. Only 2 of the 4 wired in
Two pointing back
40921069072_4f7777e3b4_b.jpg20180322_221322 by James Pate, on Flickr
Two pointing down
27091999088_db32f6e171_b.jpg20180322_221343 by James Pate, on Flickr
And out put of only the two on the driver side. (the interior lights were on as well)
40921070102_00d11127c1_b.jpg20180322_220121 by James Pate, on Flickr
40253765804_864ef3f701_b.jpg20180322_220143 by James Pate, on Flickr
meandmyhoe20
