Push to start button install
Blackie
SoCal
So I installed a DEI 5705v Alarm/Remote Start a year ago along with the DEI DBALL2(to bypass the Passlock 2 system), 2 DEI 530T window modules, and the DEI VSM300(to lock/unlock and remote start from my phone). Here’s a great tutorial (with pics) for alarm/RS installation in our trucks:
https://www.the12volt.com/installbay/forum_posts.asp?tid=133000
2 weeks ago I installed the DEI 2102T PKE system and that’s what allows me to walk up to the truck without having to push any buttons and have it unlock the doors. Install was simply plugging the 2102T into my alarm/RS with the provided D2D cable. It took longer to run the two antenna’s to the pillar between the doors than anything else.
https://www.amazon.com/DEI-Passive-Automotive-Automatic-unlocking/dp/B0096DLZLK/ref=sr_1_1?ie=UTF8&qid=1517860077&sr=8-1&keywords=2102t
This past weekend I installed the push to start button. The unit I purchased integrates into an aftermarket alarm system which kills the power to the push button while the alarm is armed. When the alarm is disarmed, the button gets power. The price of this kit was only $20 but there are a few steps necessary to make everything work. First, you have to permanently bypass your Passlock 2 system in order for the push button to work since you will not be using the key in the cylinder. It is very easy to do if you follow this tutorial:
https://kingbain.com/how-to-permanently-disable-gm-passlock-system/
You also have to bypass the shifter interlock (also since you will no longer put the key in the cylinder). I didn’t get a very good picture of the shift interlock but in the picture you will see the red circle. Just to the left of that there is a tab you push down and that cable pulls out from where it is plugged in. This bypasses the shift interlock so you can shift gears without the key installed:
https://drive.google.com/file/d/1w5ZXOI4jXsTzyT0_e-FNcWBfqkJYzT5I/view?usp=sharing
At that point you just have to install the push to start button. The unit comes with 6 heavy gauge wires that need to be hooked up to the heavy gauge wires in your ignition harness. You need to wire up a relay to make the 1 Accessory wire in to 2 outputs since our trucks have 2 Accessory wires in them. You then connect 4 wires to your aftermarket alarm (as shown in the install instructions). Then plug the push start connector into the module and mount it. This is the unit I purchased:
https://www.ebay.com/itm/Car-Auto-One-Push-Ignition-System-Engine-Push-Start-Stop-Button-Remote-Starter/132224242628?hash=item1ec92dd3c4:g:eIgAAOSwnK9ZPlu4
It may sound like a lot but if you’ve installed stereo’s or alarm/remote starts in the past it really is just following the links/tutorials I posted above. Any questions feel free to ask.
Blackie
Blackie
SoCal
It is over the factory key location:
Blackie
Blackie
SoCal
Wow that’s an awesome mod. Is there a way to turn on accessory without starting the car?
To turn on accessory you push the button once without pressing the brake pedal. To put the truck in the run position you press the button twice without pressing on the brake pedal.
To start the truck you put your foot on the brake and press the button once.
The push button works like a key.
4myfreedom
Washington, DC
So no more key ! The alarm arms and disarms it?
Blackie
Blackie
SoCal
Hell Yeah Bro. Definately gonna look into doing this setup on mine. How much $ in all did u spend on everything?
I spent:
DEI 5305v alarm/remote start unit-$118 ebay
DEI DBALL2 bypass module-$37 ebay
DEI 530t window modules (2) $60 ebay
DEI VSM300 smart start module-$108 ebay
Smart start activation-$15 ebay
DEI 2102T passive keyless system-$20 amazon
Push to start kit-$20 ebay
Wire, relays and connectors-$30
Total-$408 Total parts
Yes. I specifically bought this push to start kit because it integrated to my aftermarket alarm system. There is a wire that hooks up to the alarm so when the alarm is armed it kills power to that wire that powers the push to start button. When I disarm the alarm, it sends power to that wire that powers the push to start button allowing the truck to start. No need for me to use keys anymore. I only have a small keyfob on my keyring which is the sensor for the 2102t system to automatically unlock the doors when I walk up to the vehicle. My keys never leave my pocket. With this setup I really don't even need that fob. I can arm/disarm the alarm system from my phone and then get in and push the button and go!
Also, nothing I have done above is permanent. I can remove everything and the truck will function with the key like it did before I installed everything.
4myfreedom
Washington, DC
I spent:
This will work with my Excalibur alarm and auto start ?
Blackie
Blackie
SoCal
As long as your alarm has a negative trigger when armed wire then it should. That is the wire that kills the power to the push to start button when the alarm is armed.
exninja
At first I was like "why?" but then I decided that's pretty cool. Congrats!
shreksbrother
Auburn Hills, MI
To piggy-back off of your cool project, I just completed installing passive key/push button/remote start in my Yukon.
Since I did not have an existing alarm system, my deployment consisted of three parts:
The passive key/remote start/push button kit:
http://a.co/csjbOor
As with any other kit, the wiring is a bit complex, but it was made easier by my next purchase...
The brains of the operation:
http://a.co/amVWCIi
I understand this is not 100% necessary, but it really made wiring everything up a snap. Unfortunately, I did not realize that it had to be programmed, which led me to my third and final purchase of the project...
The programmer:
http://a.co/dlrcx4B
This little hockey puck allowed me to program the brain, and made life incredibly easy. It defeats Passlock, initiates the lock/unlock process, and a few other features I did not use.
The Fortin device also had an awesome wiring diagram that makes it Barney simple to do all of this magic.
Everything cost me about $240. I plan to sell the programmer since I'll likely never again use it, so hopefully that'll put my cost down to about $200.
As mentioned by the OP, you do have to disable the ignition shift interlock. It took me longer to separate the halves of the surround than to defeat the interlock.
Now my key fob stays in my pocket, I walk up to the Yukon, it unlocks. I get in, press the start button and away I go. I walk away and it locks... Very spiffy.
Next on my list is to buy a pair of rear door handles to replace the front ones (to eliminate the key holes) and to get my trunk button keyed to the Yukon for emergency entry. It is also worth noting that the starter kit I bought has this keypad that goes on the inside of the windshield. You can then type in a code (that you set) to gain access if the fob battery dies. Automagically the keypad works through the glass... No clue how that happens.
After that (and once this has proven itself for a few months) I will design and 3D print something to cover over the ignition switch... That way I do not need to actually remove it but can retain it in case of failure of this sstem.
I'm very pleased with the setup. Worthwhile and nearly invisible setup except for its convenience! Plus the remote start feature will be priceless as my company is relocating me to Michigan in a few weeks!
4myfreedom
Washington, DC
http://a.co/csjbOor
http://a.co/amVWCIi
The programmer:
http://a.co/dlrcx4B
ok I have an Excalibur alarm how would my install differ?
shreksbrother
Auburn Hills, MI
@Blackie may be able to answer better since he had an existing alarm. I do know the kit I got for the remote start has an alarm interface built in, so it's worth exploring if you go that route.
SuburbanPassion95
