HiHoeSilver
Away!
Chicago
I might try the 3.5mm jack to the xm radio first before buying a new head unit. I want to do my suspension before anything else
I did the same. Hid the jack in the back of a cubby and got a little 3.5mm Bluetooth adapter that plugs in back there. You'd never know it's there and works great.
Bombsquad85
Northern VA
Link? And howd you wire the 3.5mm jack I see there's 3 prongs to it. I'm currently looking for the walkthrough but if my memory serves me right it only shows 2 connections
HiHoeSilver
Away!
Chicago
Here's the jack i used. It is "switching" so there is no bleed from the XM. The only trick is if I want the xm, i need to unplug.
HiHoeSilver
Away!
Chicago
Here's where I put it.
Here's the adapter. I bought it at frys.
I got some ground loop noise, so I added this splitter. Fixed.
BigDaddy13440
Rome, NY
That is quite the idea and project. This just came to you while you were sleeping?! lol doe it help that I also have a 3in body lift already installed as well. So any obstacles underneath the body are already 3inches out of the way!
Dude, you have no idea what thoughts run through my head while I'm sleeping (or trying to!).
I've been known to wake up (or at least 1/4 of the way) and start sketching out plans for a deck, or writing down ideas for a kitchen remodel. I'd say at least half the time, if I can't sleep, it's because I'm dreaming about trying to figure out a solution for a project that I'm not even actually doing!
Bombsquad85
Northern VA
PG01
Up here to the right
Im the same.. some of my best ideas come to me right when i wake up, (after i take care of the wife if ya know what i mean), a few minutes later and im drawing plans out......hehe
TheAutumnWind
The one i used disconnects the "through" signal (xm) when you plug in. Yours will tap into the xm line, so you will need to tune to channel 0 for use. On the up side, you won't need to unplug like i do.
Oh i can do this and keep my xm?would be nice to have bluetooth... I always assumed this would remove xm functionality.
Scottydoggs
NJ
take 2 on the tear sewing is much better. looks like this is one of them things you dont do well right out the box.
i left the first set of stitches in there, seemed to help. new stitches went in tight and stayed tight.
step back a bit and you hardly see it.
to tonyrodz, the largest needle is full round in that kit of 4.
Damn son great job.
HiHoeSilver
Away!
Chicago
Yes you can. Just not at the same time.
I still done understand the plug in part and the thru part haha
You're sharing the line to the HU between xm x and aux. The switching jack only lets the HU see one at time. With yours, the Huh would see both all the time, so channel 0 is blank if you're using the aux.
PG01
Nice, looks better... you prob didnt have your glasses yesterday....thats why.....;)
That class in high school helped, looked at your notes huh?
Bombsquad85
Northern VA
Do you have a picture of yours installed?
Scottydoggs
NJ
i had them glasses yesterday too. made one stitch with out em and had to go back in to get em, getting old blows.
i think it was just the tear pulling back on me i guess. damn stitches just kept opening up, this time you gave em a tug and they stayed put. i used a doubled thread this time. last time was single thread. might have helped too.
HiHoeSilver
Away!
Chicago
Try this.
This is the xm module behind the glove box.
The green/white and brown/white are L and R (forget which is which) to the HU. All you're doing is interrupting or tapping into them to insert your jack. The black/white in the corner of the harness is the ground.
Escalade2007
