HiHoeSilver
Away!
Chicago
Bombsquad85
Northern VA
Oooooooo.... Never seen that one. I got a couple things that won't fit in my blasting cabinet that might work for... Thanks.
No problem if you get it me me know what you think. I think I'm just gonna get the spray gun for now. Let me know if you think it'll work on the chrome rims
05Single
afraid of the dark
I did a few things this week to the old girl:
Rebuilt Front End - ie all new upper & lower control arms, ball joints, inner & outer tie rods, etc...(still have to replace pitman & idler arms when I get time)
3" Lift Spindles up front
3" Lift Spacers and 2" Hub Centric Wheel Spacers in rear
3D Molded Wood Dash Kit
02 Escalade Knobs
08-14 shifter swap
Dash Cam
Nice clean work. Need to replace that cigarette lighter with a usb
4myfreedom
Washington, DC
How about this for a simple thread. I know a lot of us do simple stuff to our trucks everyday and we don't make a new thread for everything we do. So if you did something neat, simple, or just want to brag about a new cool piece you threw on your ride post it up. I figure this thread will also bring inspiration to others as well.
I'll start.....
Today I did some spring cleaning to the my '01 Tahoe. I washed it and cleaned out the inside. I also ordered some new JL audio speakers for the doors and front and rear Weathertech floor mats. I also put some sound deadening material in the doors.
Jack your post count up, and post away.
-Ben
I need sound deadening as well post pics
4myfreedom
Washington, DC
I'll start.....
-Ben
Austinite
Austin, Tx
Nice clean work. Need to replace that cigarette lighter with a usb View attachment 191529
Yeah I did that with the one on the right, but the USBs are connected to the head unit. I can charge the phone with em and connect to the head unit, but they don't fast charge. I haven't found a USB socket like that yet that has fast charging or I would change it out.
However on a side note, I took a chance and ordered this Daystar Switch Pod for a Jeep Wrangler and it fits the A-Pillar perfectly. I just need to get some custom horizontal rocker switches for it now. I'll post some pics when I do.
95escahoe
Thank you! Looks like I will have to take the bumper off like you said to get this cover off. I couldn't reach all the clips for the cover. GM can suck it for making something as small as changing the license plate bulb holder this difficult
Spray the bolts with PB blaster or a similar product for a few days so they come off easily
05Single
afraid of the dark
Mine has usbs on the left and a usb and aux input on the right hooked to my pioneer dd. I don't really need fast charging in my truck. It's more of an emergency charge in most cases.
treehan77
TYF Fiend
Crestview, FL
I see you went with the MB Quart 8 inch sub. Interested in what you think about the sound? Have been eyeballing that one since the Kicker that was previously recommended for the rear sub box has been discontinued
Yeah the MB Quart sub is ok. It's cheap and small so I didnt expect much. First I was disappointed, but my last system was 2 15" Alpines. Basically it just fills out the low end a little bit. Had to space the trim piece out to keep the sub from contacting it, butay be because I didnt have the factory mounting nuts or whatever that pop in the square holes to accept the bolts, so I made a plate to bolt it to. Anyway, I found out MB Quart has been bought by a Chinese company or something g and is definitely isn't the awesome stuff it used to be. But for 55 bucks, it's not bad. I only have a little NVX 300w amp running it.
treehan77
TYF Fiend
Crestview, FL
Here's the amp and a pic of the box installed. Jack still fits, had to remove the threaded rod that held the tools. I hated that damn mounting g system anyway, just used a strap of Velcro under the 2nd row seat.
I just put some flexible roof seal like putty crap under the bottom tab of the box to keep it from knocking g since it had nowhere to go into.
2B8B7ECA-95A1-4146-B2F2-6EFE21A16268.jpeg A03B304C-244D-45AD-8B3D-10FE97B9B50A.jpeg
What are you going to put in there?
05Single
afraid of the dark
What head unit do you have?
I have factory nav but it's annoying to not be able to play my music or have bluetooth
Cheap pioneer. Avh 170dvd. Not Recommend . Doesn't even have Bluetooth
Korbin_A
