2002 tahoe lowered 2/3 sways really bad
BADRIDES
I called Autozone and told them how long my Belltech endlinks were and they had me a set waiting on the counter when I got there. I have the greaseable sway bar bushings from Energy Suspension.
LINTZ0718
LINTZ0718
I am running Energy Suspension front endlinks and their poly bushings. On their website, in the PDF catalog under universal endlinks, they detail how to measure and order them. They need to be shorter it you're lowered in order to make the swaybar work correctly. Same in the rear, but that DJM kit you bought has the shortened rear ones. DJM also makes huge swaybars that work great, I'm running them front and rear. I highly recommend beefier swaybars, the stockers are weak. You can't go wrong with DJM and Energy Suspension.
Thanks for great info
LINTZ0718
LINTZ0718
Do you know the length you have ? I only have 2in drop spindles no keys
I also have 2" drop spindles and stock keys. I figured my fronts needed to be 1/2" shorter than stock according to my measurements and the Energy Suspension part number I ordered to accomplish that was 9.8149R.
LINTZ0718
LINTZ0718
Nice and it helped the front?
BADRIDES
I have the Energy Suspension sway bar bushings and love them
ezstriper
I do not know as of now, but we used belltech stuff and help them develop the 4x4 lowering kits in the 90's, but for years they did could not get their shock valving right and after flogging several sets on a test truck, we ended up using DJM's
HawkMD
2002 tahoe lowered on spindles and 3 inch rear lowering springs I work for Chevy and was gonna police take rear springs to stiffen it up ... I just ordered the djm trailing arm relocate kit and endlink kit and poly sway bar bushings.
Do you think it will take the rear sway out ? Should I get police tahoe springs?
Will i need adjustable rear pan bar too?
It has cai , flomaster ,bbk power plus 80mm tb long tube headers on next weekend
Just looking for sum input View attachment 189676View attachment 189677
I have front end spindle drop and 3 inch in the rear. Never had a sway issue. I have adjustable spohn performance panhard rod which you want adjustable to recenter your axle when you lower your vehicle. Also adjustable upper and lower spohn performance trailing arms. DJM relocation trailing arm bracket and DJM sway bar links. Sway bars front and back are Bell tech. Going to get some 6 inch drop springs with helper bags and also install upper and lower DJM control arms to finish the final drop. Your sway bar links have to broken or your sway bar mounts are loose for you to be swaying like that. Tell us what you find out , good luck.
HawkMD
Still coils are not going to fix your sway issue.
LINTZ0718
LINTZ0718
Djm kit installed
LINTZ0718
LINTZ0718
Hey did the 1/2 shorter endlink tighten up front ?? Does it hit inner tie rod
It just lets the swaybar sit parallel like it's designed to do which makes it function properly. It's not going to "tighten up the front"; the only thing that will do that is new steering components. Nothing hits the inner tie rod.
CKendrick
