Cluster LED swap Mp lights
4myfreedom
Washington, DC
Ok put red LED 194 in yesterday put cluster in and no red lights. No blown fuses Dimmer works healights work no blown bulbs? I need help
How do you tell if the polarity is backward ?
if there is no marking on the bulb then you will have to test the bulb for polarity, some are non polarity but if it has a positive negative then you will need to also check the polarity where it is mounted. and check each position GM likes to play polarity roulette because on a standard bulb it doesn't matter.
4myfreedom
4myfreedom
Washington, DC
4myfreedom
4myfreedom
Washington, DC
Ok bulbs were turned the wrong way so simple but thanks for responses. Learned a polarity lesson lol
TheTahoe
