juan84
They sure do
Sent from my SM-G920T using Tapatalk
They sure do
thanks, now if I can just find a couple of the positive cable firewall retainers and a metal S clip that holds the coil harness on the bracket I'd be a little more un-pissed off right nowNice man, that looks great.
nowhere, I spent about 2 1/2 hours searching every possible keyword, looking at pictures, looking up the cable to see if there were just the connectors anywhere, NOTHINGNot even Dorman? I went to look but there site is under maintenance right now.
My garage stays nice and toasty....lolhey if you guys in the super cold weather want to add a block heater they run about $60 online and if you have the aluminum block it goes on the drivers side front just under the head, if you poke you head down near the old battery location you can barely see where the block coolant plug where it goes
I have the same problem. Mechanic recommend taking it to a glass shop. He couldn't get it glued back on and a previous fix also failed.Had this cable from the defroster pop off today, it’s been very cold the past week. Solder it back on?
