Which transmission lines?
Cbark2305
Going to replace my leaking lines and I’m not sure which ones to get. I’ll attach a picture
I have a 07 Denali xl
depends which one's leaking?, does it have transmission cooler in front? and jeez napa is pricey, rockauto will be cheaper same part, those will come pre bent look and match it up same bends
C
Cbark2305
Yes I have a front cooler
C
Cbark2305
The ones that are leaking are the 2 that run up to the cooler. I’m confused about the with or without rpo code
PG01
Up here to the right
1 has a trans cooler, the other doesnt. Look in your glovebox for rpo codes
Better yet tell me, do you have a trailer brake controller, from the factory, by your left knee?
C
Cbark2305
No I don’t have a trailer brake controller
C
Cbark2305
Guess I’ll get those and the motor mount ordered tonight and start taking things apart while I wait
sk1dm4rk
The transmission cooler lines are known to be a problem area. There are threads around like this: http://www.cadillacforums.com/forum...ssible-quick-cheap-solution-crappy-leaky.html that show how to fix using some fuel injection hose and double hose clamps.
I did this to my Esky and not a drop in almost 2 years. Much cheaper and likely lasts longer than replacing the hoses that are still prone to leaking at the metal to rubber junctions.
C
Cbark2305
Is yours a 07+ I just read that and they did it for earlier model
sk1dm4rk
Yes. My Esky is 07. They went over the top in that link. All I did was use a small pipe cutter to cut behind the rubber/metal junctions and got a couple feet of Fuel injection hose and hose clamps. There is not much pressure in those lines. The double clamps seal it up, so no need to flare the metal ends or anything.
Done. Cheap. Better.
C
Cbark2305
Did you take the lines out or leave them in while you did it? I like to see a how to with the pictures
sk1dm4rk
The good thing about this is that if it doesn't work for you, you are only out $20 and you can either find another solution or order the OEM hoses.
Good luck
C
Cbark2305
Good luck
Yea Napa has the ones I need in stock I’m pretty sure. I’ll have to see how rusty they are when I get under there in a bit if they aren’t then I’m gonna try this. Just not sure if I should flare them or not.
Drewphil
