#1taho
5150TAHO
niagara falls ont
So my ball joints feel ok and no clunking. Might try just replacing the boots for now since i dont want to have to deal with getting another alignment.
I just replaced my ball joints. They had no movement but when I took them out they were definitely screwed. I am not sure how they didn’t fall out. Funny thin is I have had a bump steer problem for two years and couldn’t solve it. I checked the front end 20 times and had other shops and people check at least 10-15 times. For what they are worth I would do them.
#1taho
5150TAHO
niagara falls ont
Highly unlikely you have more than one regulator going out at the same time. Especially since you said ALL the power windows. You must have a power problem. As in maybe a ground problem?
Check the wires under the drivers seat. The orange one burns up. I thought the same as you and replaced the switch. And I was wrong. Look under your out seat and check the big plug.
05Single
afraid of the dark
I didn't exactly do anything to my truck this weekend, but I did get something for it. I drove almost two hours yesterday to go to a "You-Pull-it" junkyard that I have never been to before. I went because they had plenty of 00-06 NBS trucks and SUVs listed in their inventory, and BOY DID I RACK UP!!!!View attachment 188115
Nice score !
I killed my HD grille
I'm not sure what happened :poker:
Bombsquad85
Northern VA
What year is your Tahoe?
Seat motors should be the same. I know you need to reflow the solder connections for the PRNDL. Hopefully someone will chime in and be more specific.
Thanks Tony. My tahoe is an 01 and the Denali is an 05.
Appreciate the info on the PRNDL
Hopefully the seat is straight forward.
Also will the cold air intake I have on the tahoe 5.3L fit on the Denali 6.0L?
mals
Western Mass
is it an easy fix if everything in the gauge cluster works minus the gear shift indicator?
I had the same problem on my 2005 Denali. There are a bunch of videos on youtube if you search, but this one covers most of the points and is the one I normally link to: Fix for GM gauge cluster PNRD123 Light
It was not that difficult to do. Shouldn't be a propblem if you're motivated to do it, and have held a soldering iron before.
Bombsquad85
Northern VA
Thanks man. And my hand is pretty steady ;) I was a bomb tech haha
ScottyBoy
Shreveport, La
Yes, a cold air intake from a 01 Tahoe will fit a 06 Denali, but not vice versa. The 06 has electric fans, and the intake tube is slightly larger. The 01 intake tube is made to fit over the fan shroud of the clutch fan, the 06 tube is not.
Bombsquad85
Northern VA
Will the stock airbox from the Denali fit on the tahoe? 01 tahoe 05 yukon... I don't have the stock airbox for the tahoe
05Single
afraid of the dark
Dafuq did you do son??
I rear ended a prius :oops:
Lol ok
I was grabbing some box's from the top shelf in the garage. I just took the grille off a couple days ago to prep it for paint. Was very excited for that.
As I grabbed a box another came with it and landed on the ds wing and broke it completely off. I said 'no box only I can destroy my truck parts'....so i was like
TwiztidPixel
Anderson, SC
Is that HD grill a direct fit part? Is that bumper cover needed? Dunno why but I never even noticed it was different until now!
Lol ok
As I grabbed a box another came with it and landed on the ds wing and broke it completely off. I said 'no box only I can destroy my truck parts'....so i was like View attachment 188129
Cool! My kind of guy.
kwOH
Banned
Lol ok
Lmao
ScottyBoy
Shreveport, La
The grill needs some trimming on the lower edge, and some of the mounting pegs behind it and it'll fit right in.View attachment 188135
Grill only needs trimming if you are using it with the stock Tahoe/Suburban bumper cap. If you install the 2500HD bumper cap, then you don't have to trim a damn thing on the grill.
Oops, forgot to add that. Doesn't some relocation of the bumper brackets need to be done if you want to use the HD bumper with the grill?
Hodmjstone
