Oil consumption
dreww2001
STL
So i know its normal for older cars to consume oil as they get older but the past month ive had to add about a quart of oil into the car in less than 1,000 miles. Is this normal or could i be looking a more serious issue. Just rolled 150k and ive heard this is when the AFM problems start to occur. Any warning signs or stuff to check? I know this can get expensive quick and i pushed a whine off for too long then it costed me a whole diff rebuild so any help would be appreciated. No leaks either.
NGAneer
NWGA
Step 1: Get a catch can to capture oil vapor
Step 2: Tune out the AFM
These two steps should really help or eliminate oil consumption.
SethSwitch
I have done both and they do help. I have also heard of switching to a higher oil weight but have not personally tried that.
dreww2001
dreww2001
STL
Ive read that about the oil weight, thats only something i would do if my mechanic suggested it.
NGAneer
NWGA
I still run old 5w30 with no AFM (BB Tune) and a catch can. Honestly can't say the last time the amount in the catch can was north of 4 oz.
Andrew1068
Binghamton NY
Sounding like an all out newb what is a catch can and where does it install? Also what tune/ tuner do you suggest? Thanks
HiHoeSilver
Away!
Chicago
A catch can is an oil /air separator that installs in the PCV line between the crankcase and the intake manifold. It's job is to remove oil from the air being recycled from the crankcase vent back to the intake.
The most popular tune here is Black Bear Performance. They have a few methods to choose from.
Andrew1068
Binghamton NY
Awesome thank you very much. I'll be digging into research now.
Plimbob
Des Moines Iowa
I have a 07 with 244,000 on it and it used to use a quart about every 700 miles. I bought a Range unit which plugs into the socket that you use to check engine codes. The Range shuts down the AFM and the oil consuption went down to around a 1/2 half quart between changes.
May want to look into that option as well.
Conedaddy
