QA1 10-350 10" springs
rigo_jones
going against
DENVER mexico
Got some used qa1 springs off ebay for $20.i dont know if i got the right ones since everyone is going with the progressive rate springs. these are just regular coils that work great.anyways heres some helpful info if you are looking to drop your truck with them.
springs
02 z71 vs. 00 suburban vs. QA1 10-350
truck on qa1 10-350 32 1/2 inches from the ground cant remember my tire size.
how the panhard bar sits
more info.
-its a 10 inch coil with the entire weight of truck it compressed to 8 inches
-roll pan sits 12 inches from the ground
-theres about 4 inches of clearance between the frame and rear axle with djm free travel mod.
-shock eye to eye measurements with full weight of truck are 17 inches, with djm shock extenders is 19 inches. to use these springs you will need to find a shock that extended eye to eye measures no more than 19 inches or your coil will pop out. iirc theres a djm shock that is 19 inches eye to eye part number 1900c i think.
-rear lower control arm has about 1 inch 1/4 of play. recommend to get the djm kit rk2000. i still need to get mine from tony(im broke:emotions122:).
- at this point the lowest point of the frame sits about 7 inches from the ground.
-although i didnt have shocks on the coils felt like they were a bit bouncy but not much compare to stock as i bounced the truck up and down.
-as far as the panhard bar sits i know nothing.
-c-notch might be needed.
-keep in mind going with a lower coil will need a smaller shock. qa1 sells a shock that extends about 18 1/2 inches but are over 180 each if i recall.
any more info i find will add.
Grocery Getter
A guy with a truck.
Phoenix, Az
Hmmmmm......please post how they ride once you get'r on the road. 32.5 is just about where I need to be to be level...... GOOD WORK!!!!!!
BlizzardX23
Sacramento, California
Looks like you came in and stole Max's thunder lol...you beat him to it haha
Congrats on all your work...I'm for sure going to have to steal this mod!! Cant wait to see pics of this thing parked out on the street and how it actually sits! :D
Modded
That Guy
My rear sits at 33.5" so I am surprised the Qa1 is only 32.5 from the ground.
I like your stup alot, the truck needs like two washes lol!:Handshake:
R
rigo_jones
going against
DENVER mexico
lol thanx ive been actualy searching around on the qa1 springs for a while but very low income and info doesnt get me any where fast. and since i needed to find out the length eye to eye for the shock i figured why not some pics. ill be honest im broke im unemployed but getting unemployment checks every 15 days. what ever i have left after rent and all that shit i dump it to the tahoe. im almost done with front all i need is shocks. it just sucks that there isnt that much info on this ive been searching and looking for quality parts for cheap so far i got the springs, lcas, lowering keys, shock extenders and im at about $230. im also getting together the 03-06 font end at the same time. :cool:
---------- Post added at 07:59 PM ---------- Previous post was at 07:58 PM ----------
sure will. thnx
---------- Post added at 08:03 PM ---------- Previous post was at 07:59 PM ----------
i know i thought it was going to be hella' dropped but its not.
yeah i hear you on the washes but theres still snow and wouldn't be worth it.
BlizzardX23
Modded...your at 33.5?? I'm only at 34.5
32.5 would be super nice on my truck..
Rigo...I have 5 inch drop coils in the back of mine...
I have shorter sway bar endlinks, shorter drop shocks, trailing arm relocation brackets, free travel mod...
Would I be able to just purchase the QA1 Springs only and swap them?
Would I be able to
R
rigo_jones
going against
DENVER mexico
u should but u would need some shock extenders and a shock that is 19 inches extended. if you were to go with the 10 inch qa1 coil, what u want is the shock to not let the rear axle fall enough that the coil would pop out.
theres a djm shock 1900 is 19 inches and 1800 that is 18 1/2 inches
Modded
That Guy
Would I be able to
Yep im at 33.5 at bothe rears, fronts are 34.5 for now but fixing to be lower real soon!!
Badluck
SE WI
Thanks for the info. Great job sourcing all your parts for $230!
R
rigo_jones
going against
DENVER mexico
thanx goodluck.. it a lot of time and searching but paid off in the end...
does any1 know the size of a djm or belltech 5 inch spring with full weigh on?
Badluck
SE WI
McGaughy 5" coil sits at a hair under 8". I don't have a spare tire or 3rd row seat.
I need another 2 inches out of the back for the truck to sit level.
R
rigo_jones
going against
DENVER mexico
u serious? thanx bro im gonna go with a 9 inch coil then. was this with full weight on?
Badluck
SE WI
Yes. All I have in the back of the truck is the stock suspension parts. If you get 2" compression I would need a 8" coil. I plan on doing a c-notch anyway.
R
rigo_jones
going against
DENVER mexico
yup 8 inch for you. i want to notch it too, have u been in an air suspension car/truck before? im wondering if the ride quality is good with airbags. thanx again for the info bro.:Handshake:
Badluck
SE WI
Never ridden in a bagged ride. My plan is to bag the rear of my truck. I bought all I need from a fellow tyf member but am still waiting for the parts from him. I am just going to use schrader valves, no compressor. I am hoping that the bags will smooth out the ride, especially since I want to go 2 inches lower than the 5" drop coils I have now. I'm also going to make an adjustable panhard bar to get the rear wheels centered.
R
rigo_jones
going against
DENVER mexico
i hear you i was thinking of doing the same my self but dont know yet u should do a write up or post some pics of the install i might copy you. lol :)
Max
Mile High
Denver
Where did you measure from? My belltechs don't sit that low and I was the same height as a friend's denali with the 3/5 mcg kit with identical height tires before I pulled my isolators. I think the 9" qa1 450 springs are gonna be the ticket for a 7" drop, guess there is gonna be some trial/error involved with these things. Thank god for summit's return policy lol.
Badluck
SE WI
Max
Measured driverside from bottom of upper mount to top of bottom spring mount.
I plan to do a write up when I do the install. I can't take credit for the idea, found it here just search set it and forget it.
TEXAS DEMON
with a vengeance
texas
on the pan hard go to www.suicidedoors.com. they have adjustable links at a very good price.go to the 4 link parts section. the oem bar is 33.5" so i need something that is 1" to 1.5" shorter
JamesinAbilene
