Let's see some pics of some lifted and leveled
01Konvict
Boats n Hoes
Raleigh/SML
how do you measure how much it lifted? i had a shop do it
Do what the others said here to measure. By the looks of the picture I would be worried about angles also. Everything looks at max angles with uppers on droop stop. If that’s the case definitely need to loosen up torsion key bolts to a safe condition. Post pics of upper arm to confirm suspension travel.
CamReynolds
i think the next time i need an alignment ill drop them .25-.50 an inch.
CamReynolds
Try like 1-1.5 you’re gonna eff some parts up running like that...
but then its not level so whats the point of having keys? I dont think all of these companies would make torsion keys if it were so bad for your parts
Drok
Cold place in the north
Joined the lifted crowd, 2.5/1.5 just need some nice ats now..
Jonah52
Senor ******
Cleveland
That’s like saying McDonald’s wouldn’t selling you hamburgers if they were bad for you....
You really need to get different upper control arms or decrank.
@01Konvict can you advise on the amount of room there should be between a droop and UCA on a NBS. I know you want level but you’d rather not have your CV’s binding. Those angles look rather extreme.
paul lombardo
not very good pics
- with 2.5"/1.5" level and 285/65/18 BFG ATs, nerf bars removed
- with corsa touring exhaust
- with frontier grill guard
not very good pics
looking to do the same thing. how do the heavier tires ride and at what air pressure are you running them?
01Konvict
Boats n Hoes
Raleigh/SML
The E class isn’t bad just a little heavier. Run mine at 40 on no tow loads and 45 when towing 6k. Shouldn’t be too much difference for you
PG01
Up here to the right
Jaytizzle
Looks good, really good..... but imo it needs a little more lift (i kno u said prerunner but i still think it needs more lifty lifty.....:D)
:2cents:
Just a little bit more but the customer wanted it to sit just like that!
sarneson91
Alexandria, VA
In case anyone was wondering 305/55r20’s fit on a ccm 2.5/1.5 with minimal rubbing at full lock! Got a set of Backcountry MT’s from Les Schwab, originally was gonna go with The mastercraft cxt but these were cheaper and basically what I was looking for, will post pics this weekend when I clean the hoe, took her to the mountain today and she got a little dirty
Nygator
New York
Hello new person here I have a 2011 Suburban SSV that I bought did the bilstein shocks 5100 all the way around . Front I have set on the second click with two inch under strut spacer and rear I have two 2 inch spacer . Have stock 20 inch wheels with 275 60 20 no rubbing on full lock either way . Have put 4000 miles since I did the work no issues driving in NYC everyday.
albac
