Removing Denali body moldings
mdcrossley
Any one have any suggestions for removing all of the Denali body moldings? I watched some you tube videos for removing basic body moldings (heat up, remove, then use 3M eraser wheel) pretty much same process?
Also planning on removing running boards. Anything I need to know to make the job easier?
Thanks!
DenaliBQ
you can use gas to remove the adhesive for the molding much easier and less chance of damaging paint as long as you wash and wax right after
PNWMuseumman
Bow Ties Are Cool
PNW
X2. If you do all that no reason to own a Denali !
I suppose the arguement could be made that you would still have the Denali running gear: 6.0L, all wheel drive, suspension...etc. But I'm still curious to hear the reasoning. Personally I freakin love the Nali's... But, to each his own.
DenaliBQ
if your removing denali running boards and want to sell them let know
J Mac
Newport News, VA
Sounds like you have the right process. I did the same thing on my Denali. It'll take some time to cleanup all the adhesive residue. I just kept using the eraser wheel and liquid rubbing compound. I did have some rust on the rear quarters that was uncovered once the cladding was removed. Had to get both rear lower quarters replaced.
I don't care much for the Denali cladding either. But when buying used, can't always wait for the exact one you want. That was my case. I got a great deal and really wanted the 6.0 for towing our camper. So now I just need to swap front ends for the later year Sierra and get me a chrome rear bumper.
Oh...once you have it all removed...put it on CL and recoup a few dollars! Someone will want it!
wphtexas
TX, CO
Had the moldings removed on my 2011 Silverado easily. Went in for a exterior/interior wash and detail. For an extra 50 bucks, they removed the moldings cleaned, light buff, and wax.
wphtexas
mdcrossley
mdcrossley
I am interested in the stuff depending on location!
I have removed all the cladding and running boards. Denali is white. Everything is 100% intact and functional. I am located in Middle TN (I’ll be in Huntsville, AL) this weekend. Let me know if you are interested.
mdcrossley
mdcrossley
What kind of compound did you use with the eraser wheel? It’s getting 97% of it off, but leaving a thin crusty line. You can see on the pic where I have done the back door and rear panel.
05Single
afraid of the dark
Why chrome rear bumper ?
PexoA78
