What Saved Your A$$?
ScottyBoy
Shreveport, La
Thats what the 4 d cell maglite is for....those dam ‘ya never know’s
I only have a 3D cell maglite, but it is always within arms reach. I can't remember the first person to do this mod, but I have seen several members on here mount a maglite under the glove box. Here's mine.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
DAMN!!!! Just DAMN!!!!!
Jumper Cables! Always used them to help someone else.
Yes!!
Gorilla wrench saved my ass several times. Tire shops usually tighten the lug nuts way to much and it's a pain using the car's wrench. Bought a gorilla years ago and it's so much easier. Amazing what leverage can do.
https://www.amazon.com/Gorilla-Automotive-1721-Telescoping-Wrench/dp/B000CMJ2KU
Yes!!!
my wheel wrench is under the driver seat... cause ya never know
Yes!!!!
All of the above and a tow/recovery strap.
PNWMuseumman
PNWMuseumman
Bow Ties Are Cool
PNW
Yes!!
Yes!!!
Yes!!!!
What kind of Tow/Recovery strap do you have? I've been wanting to add one of those to my "Essentials" kit, but I've been hesitant about which one to buy. I don't want to inadvertently end of with a crappy one, because when the situation arises that you need that strap... You really effin need that strap...
89Suburban
SE PA
Just the regular cheapo shit. If this can't handle the job call a tow truck because I'm not wrecking mine. It's so long you usually wind up doubling it up anyway.
https://www.walmart.com/ip/Capri-To...75035&wl11=online&wl12=47505723&wl13=&veh=sem
PG01
Up here to the right
Mine is right next my seat in between the console and drivers seat. Ive had/have one in every car ive owned, my accord has the 3 d cell and truck the 4. It slides right in between on top of seat track, snug too doesn’t move or make noise.
ScottyBoy
Shreveport, La
Speaking of making noise, the first time I mounted mine it made a shitload of noise. I quickly realized that it was the batteries inside the flashlight rattling around. So my solution was to slide the batteries out and wrap a paper towel around the stack of them, then slowly slide them back into the flashlight with the paper towel still around them. So it's essentially a paper towel wedged between the batteries and the metal flashlight housing. Worked like a charm because it's never made a lick of noise since then.
MadDogDelpho
Texcellent
I have a Harbor Freight knock-off mag-lite, right next to my seat. Then on the other side I have a Walmart survival machete, with a big-ass Tanto edge, cable-cutter hook, and a sawblade, because again, you never know. (https://www.walmart.com/ip/Camillus-Carnivore-X-18-Machete-Black-Handle/189347215) Couple jackets and a sleeping bag and travel pillow under the back seat allow me to sleep anywhere. And a couple other tools, jumper cables, and a crowbar in a bag in the back.
Kendall69
Story time!
What one thing are you so glad you had in your truck that totally saved your a$$ and why?
Be it while 4-wheeling, Road-tripping, or daily commute. What one thing will you always keep in your truck after that experience? Doesn't need to be life-saving or dramatic, maybe it was a random granola bar stopping your transition from Hangry to "I'm gonna die" hunger. Or maybe it was a previously forgotten stuffed animal that was found in the 12th hour of your cross-country trip and entertained your children a bit longer. I don't care... Just throw it out there!
A WINCH. I've had a winch on every 4x4 I've ever owned, and they literally saved my life plenty of times. When you're stuck in the middle of nowhere, you need to get out and the winch is your friend. Once on a Mexico beach, this poor soul was stuck at the water line and the tide was coming in. He had a new Range Rover and felt it was impervious to getting stuck, he learned otherwise.
After I pulled out the three other guys that were buried trying to pull him out and as the water was lapping his fender and about to get into his doors I hooked up to him three separate times at 100ft per pull.
That moron never even said thanks.
ScottyBoy
Shreveport, La
Yeah, I do have a tow strap as well. I forgot about that. But I picked up a cheap one from Harbor Freight for under $15. I got one last year after my fuel pump died and I had to tow my truck back home. My truck luckily died right up the street from my house, so I only had to tow it up the block. But after fighting with it that day, towing my truck with a ratchet strap, I bought a tow strap after that and it's been in my truck ever since. I keep it wrapped up and stuffed down in that side panel with my jack and breaker bar. I also keep a hand towel and some Fast Orange hand cleaner down in there. Oh, and two other things I forgot that are ALWAYS in my truck. A tire pressure gauge, and a roll of toilet paper.
IMG_20171025_174058840.jpg IMG_20171025_173915366.jpg IMG_20171025_174334693.jpg
I
View attachment 185396 View attachment 185397 View attachment 185398
I Can see the toilet paper, but tire gauge? Lol
