PG01
Up here to the right
I’ve looked just seen steel ones.
dreww2001
STL
Fosscore
Wow man, good looking out but I'm stationed in Virginia now. Thanks for that though, glad to see their is still some humanity out there.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Copy that. Just remembered seeing Biloxi in your avatar. Plus and I was there last year at the Golden Nugget and seeing it flooded again....made me think about it. We checked in on friends in Puerto Rico, St. Maarten, Dominica, etc... Glad to hear you were out of harm's way man. :thumbsup:
Burb!!
Biloxi, MS
Copy that. Just remembered seeing Biloxi in your avatar. Plus and I was there last year at the Golden Nugget and seeing it flooded again....made me think about it. We checked in on friends in Puerto Rico, St. Maarten, Dominica, etc... Glad to hear you were out of harm's way man. [emoji106]
'preciate that man.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Installed a pml rear diff cover with a drain plug. My pinion bearings are noisy so I figured might as well start off with replacing the diff fluid. It helped a little. Maybe if there’s a suitable additive I can easily drain some out and add some in
EE4468B1-FF1D-4B88-8F14-B3489F03723F.jpeg E4D0828B-67F0-4A5D-A736-9AA20F5C147C.jpeg 732285CA-04CD-4B6B-A470-B45D1EEEFC12.jpeg
93blkongreenpro
Seemed to have misplaced all 4 newo2 sensors and a new oem ac delco brake switch. [emoji58]
93blkongreenpro
Had to tighten the manifold clamp bolt down as I heard the manifold leaking. The bolt was about to fall out. I put some blue loctite on it.
Got my oil changed and they said the front diff seal was seeping. $550 for repair. I declined that today.
Removed the chrome exhaust tips. Painted the rust exhaust high temp black. Actually looks better and almost can't even see it.
Clean inside and outside of the windshield and wiped off the dash. And help a neighbor jumpstart their car.
I think thats it.
SWSS
Smashville
Upgraded to remote start with 2 new keyfobs with a buddy that works at a chevy dealer...real nice.
Ordered seat covers from cover king in black ballistic cordura. Front set gets the molle treatment...
Sent from my SM-G935V using Tapatalk
93blkongreenpro
Driver side inside door handle broke. Heard a "snap" as I got to work to exit the truck. Had to roll the window down and use the outside handle to get out the truck. That's real nice.
GM replaced all 4 interior handle 2 yrs ago under their 100k craftsmanship warranty since the front two chrome was peeling and cut my wife's hand.
Now I'm on to order some door handles.
Lovely. It is Monday?
Hodmjstone
