Michigan
- Joined
- Sep 6, 2016
- Posts
- 286
- Reaction score
- 147
I guess you would consider it a "minor" oil leak. I don't like leaks at all, I guess who would. Lol
It is definitely a bummer since I asked the seller if it had any leaks and he claimed no, that it sits in his garage and never leaks. When I looked underneath before buying it, I checked by the oil plug and I think that's the rear main seal location and it was dry so maybe he possibly wiped it down because now it shows a little witness. I will have to take pics. So I don't know if it's rear main seal or oil pan or other?
I had the same Tahoe last year that had a minor rear main seal leak and took it to a couple shops at the time and was told it was nothing to really worry about. I still don't like the fact of knowing my truck is leaking and on the driveway.
These pictures are over a 24 hour sitting. It's definitely dripping but not a puddle for sure. By looking at pics, do you think it's enough to effect the oil levels over time? Will I need to be refilling from the leak.
What problems can an oil leak cause and should I do anything about it or is it very minor and ok?
Also it looks like there is spots in different locations on the ground if you look at the last pic. Disregard the spot at the top because that was already there. Maybe I will have to lay down some cardboard and let sit overnight and report back
