Aftermarket Bulb Suggestions
TravisRyans
Hello,
New to this forum, I'm looking to upgrade the bulbs on my newly purchased 2015 Yukon XL. I don't want HID or anything extravagant. Just some good replacement bulbs for head lamps, fog lights and reverse lights. I think I would like to move to a more "cool" color to replace the warm look which would also match the led strip on the yukon head lamps.
I was looking at these for fog light replacement:
https://www.amazon.com/Alla-Lightin...on+fog+light+bulb&refinements=p_72:2661618011
Any advice or pictures from what you have used would be greatly appreciated.
Thank you,
-Travis
Jenney72chevy
I swapped out my H11 bulbs for H9 bulbs. Extremely happy with them. You have to trim off a tab inside the connector on the bulb. Easily done with a razor. Or hot knife. Bulbs are brighter, whiter, patterns well with a wider beam. H9bulb: 1700-2200lm; H11: 1100-1400lm
Cmicasa the Great XvX
the hotter bulbs could damage the projectors. Even more if they also work as Drl on base model Tahoe and suburban. Watch out for this.
I have been running them for almost a year.. no issues and no heat problems.. they also have and actual fan in the unit. On the Yukon the DRLs are separate
20161025_152222-jpg.68505
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
The comment was specifically about the Tahoe with Drl on low beam projector.
It would be great if you could give us a shot and do a comparison. You would be very impressed with our lights. I highly suggest you to move away from led bulbs on projector headlights.
SuburbanPassion95
