2002 Tahoe project progress
Brad poiencot
Brad poiencot
Just went outside to do a final adjustment on my torsion keys. The driver side is Maxed out and I'm only at 36 3/4". Passenger side sitting at about 37" and the screw is only in about half way. Sounds like a worn torsion bar ? Or is there something I'm missing?
MadDogDelpho
Texcellent
The driver's side torsion bar usually wears out more than the passenger side, because of the greater load on that side. I would just lower the passenger side so that they're level, personally.
I've heard that that's normal as far as the adjustment bolts, that one is sometimes all the way in and the other only about halfway even when new. Mine are way different from one to the other and they've never been adjusted I don't believe.
Brad poiencot
Brad poiencot
I thought about swapping the bars out. Driver on passenger side and passenger on driver side. Might try in the next couple weeks or so.
Brad poiencot
Brad poiencot
Started removing the fender flares today. Got both front flares off and cleaned up and buffed. Came out nice. Will start on the rear tomorrow.
CamReynolds
Brad poiencot
Brad poiencot
Yep. I used a heat gun to get the majority off then used a plastic scraper with some goo gone. Then when all the sticky crap was off I buffed it with some meguiar's scratch x . Cleaned it up awesome.
Brad poiencot
Brad poiencot
Finished taking the fender flares off and cleaned up. Now gonna have to paint everything silver white to make it look good. I got a oem set of 17's from a gmc that im gonna put the new tires on that way if I ever wanted to do 3" lift spindles all I need is 1" spacers
05Single
afraid of the dark
Weird how under the flare by the rear door there's a strip of silver :think:
05Single
afraid of the dark
A little tough to see, but it's cuz they wanted the rocker silver. It's all one piece.
Yea I know but the lower half of the doors should silver too :think:
Should all be uniform, at least the ones ive seen.
HiHoeSilver
Away!
Chicago
Wasn't sure if you saw the whole piece. Seems like a weird decision, for sure. Definitely never seen this before.
Brad poiencot
Brad poiencot
Well I finally got around to doing some painting today. Took the rear bumper off along with the front to get the upper cover off to paint. Not the best job in the world but I think it will look a lot better when done. Thinking about doing a light bar on it too. Not sure yet. Need tires bad though. Then will get the lift spindles and coil spacers to go up some more.
Brad poiencot
Brad poiencot
Spray paint. Unfortunately I don’t have the spot to do a real paint job. I need to sand the whole truck down and spray it. I just think it will be a waste of money if I do.
Conedaddy
