CamReynolds
Took the yukon out on the beach. Not even close to being stuck.
05Single
afraid of the dark
Oh I thought you used a complete rear Denali bumper. Didn't know you just switched plastics. Good to know tho! I thought that most holes lined up but a few extras were added for Denali cover or hitch cover
BoxChevy216
Cleveland/Detroit
It's a bumper cover just like the rest, plastic over the steel bumper. The bumper itself bolts up, then the cover snaps or clips onto it.
The actual bumper underneath the cover is identical.
Thanks fellas. Thought I read somewhere that the Denali one was different underneath. But that makes things alot easier for me.
HiHoeSilver
Away!
Chicago
Well, I got the complete front and rear 2004 Denali bumpers (with the hitch and all). The rear was rusted bad and my painted Z71 was in pretty good shape, so I decided to put the Denali cover onto it. Worked like a charm.
mwilson62000
Senior Member
Had a shop put new e-brake shoes on about a month ago when I got my brake lines replaced. They said they adjusted them best they could, but it wasn't holding the vehicle as good as it should. Thought the cables were probably stretched. I replaced the front and intermediate cable today. (Front is absolutely a PIA) No change. Adjusted the shoes some more. I went ahead and put new pads and rotors on since they were getting old. Still not holding very well. I guess I'll replace the rear cables tomorrow.
Ended up not having to replace rear cables. Took calipers, rotors back off, shoes back off and took actuators apart and cleaned them out, then re-greased them. Put everything back together and re-adjusted the shoes. Holds great now and pedal is much stiffer.
M1Gunner
Gainesville, Fl
Flushed the P.steer fluid today. That booster is highly releived lol
Got a bit rough and bent my bump stop mount check out 2nd pic. That's gonna be fun to cut off and refab lol
When you see it
ASG-MikeS
