Get a catch can before any mods.
Smrtss1
Sounds like a vacuum leak
No. It's sounds like a hissing noise.
Vacuum and hiss sound nothing alike, they don't even have the same vowels or consonants.
Sorry, I've been drinking.
BlackDogBrian
hi guys,
question to you - I see the benefit of the catch can, one more filter - great.
is there any real point in adding one on a vehicle that already has 170000kms on it?
M3kanic
It wouldn't hurt it. And on the plus side it less oil going in the wrong area.
93blkongreenpro
After 5k. Moroso billet catch can.
93blkongreenpro
That's a lot! I had about 1/2 that with the same miles.
I bought it last jan with 89k. 07 Yukon 5.3. After reading, I disabled the afm, then did the catch can.. I dnt have any records on the maintenance, but the transmission fluid was burnt when i had the dealership change it, so it prob had never been changed.
No, I meant, I have 1/2 that amount come out of my catch can. I put around 5000 miles on it also before draining it.
93blkongreenpro
Yeah, I know. I dnt know how it was treated for the 1st 89k. So I'm not sure if lack of maintenance causes more oil in the intake
bottomline2000
Dallas, TX
The 6.0 and 6.2's don't really need them, but the 4.8 and 5.3's do.
There's an upgraded valve cover that limits the oil blow by. It's got nothing to do with engine size other than the newer engines having the redesigned cover. My catch can gets a good amount blow by oil in my 6.0.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4054336/Re:_GM_LS_engine_3rd_revision_
13yukon
What's the catch can that is recommended 2013 Yukon XL.
98000 miles. Has new throttle body that was replaced in warranty
95escahoe
After looking at this if you have a 6.0 with the PCV built into the valve cover then it's the upgraded valve cover? My 04 Escalade has the 6.0 and doesn't have a removable PCV valve it's built in as pictured
M3kanic
Most of us went with catchcans.com
93blkongreenpro
6300miles. Motor has 126k miles. 07 Yukon 5.3 . DOD/AFM disabled at 93k miles. Moroso Billet Catch Can.
The Whip
