Escalade steering wheel in Tahoe
KBones
Has anyone swapped their Tahoe steering wheel for one out of an Escalade? If so, would the heated portion work?
mr tahoe
Yes you would need the clock spring and youd need to run a wire to the junction box under the dash, its easy to do
KBones
KBones
Would i need the clockspring from the escalade just to make just the heated portion work? Would the rest of the buttins still work with the tahoe clockspring?
BlackDogBrian
watching/following this topic, as I just picked up a Caddy steering wheel last night...
fiatdale
Houstons Best
Houston
There are many threads on this, been done many times. Some clock springs have additional pins which are not being used, you can use those to wire in the heated steering wheel. Others don’t have the pins, at which you’ll need the clock spring and wire the vehicle side to power.
curbud
