No Hazard Lights and No High-Beam Lights - HELP?
PJS3
2003 Yukon
296K miles
Last week I swapped out the water pump due to a coolant leak. I disconnected the battery completely (both positive and negative connections) for the job.
I can't remember the last time we had to use either the high-beams or the hazard lights.... So this could have become an issue a long time ago or it could in some way be related to me disconnecting the battery for the water pump job.
Bottom line is... My hi-beams do not work. My hazard lights do not work. Ironically, I find this out when I'm part of a funeral procession line where we were required to turn on our high beams and hazard lights... go figure.
The low beam headlights DO work. The turn signals DO work.
All fuses are good.
My only guess right now is bad relays.... But those jokers are expensive.... $10-$20 a piece and I'm not even sure if they are the culprit. Is there some way to test if mine are bad?
Seems like according to the interwebs "I" am the only person experiencing this specific issue!!! LOL... I don't believe that though.
Can anybody shed some light (pun intended) on my situation here????
MrBalll
West Texas
If it were me I'd take a good relay and swap it with your possible bad one.
I have no real idea why those two are messing up but I'd start with a swap until someone can shed light on your situation.
P
PJS3
Yeah, that's the plan... Strange situation. Will be trying today.
M1Gunner
Gainesville, Fl
Well if the relays are not the problem... they don't share a common power or ground circuit which the only thing left that they could have in common is the multifunction switch if I'm not mistaken. So hopefully you just need a couple relays and not that switch.
nallybri
Did you ever figure this out? I am having the exact same problem. New multi function switch, and no multifunction relay have not solved the problem.
Donal
Americus Georgia
2003 Yukon
296K miles
All fuses are good.
Simplify the circuit. IF positive switched circuit: 12volts...plug in connections...switch...relays...load...ground connection.
If negative switched circuit: 12 volts...connections...load...switch....ground connection.
The high beam elements could have failed anytime. load test each bulb off vehicle. Are brake lights functioning?
P
PJS3
I did actually. Been many years ago now... But as I remember it turned out to be a disconnected wire inside the actual control switch itself. Don't ask me how, but the wire inside the actual high beam/ turn signal actuator controller had come disconnected. I either ended up replacing the switch or taking the existing one apart and reconnecting the wire. Again, it's been many years ago now... But I do remembe that being the problem. Hope this helps!
BadDaddy2003
