4l60e problem
J444HN
Hi guys, I'm hoping someone can help.
I live in the UK and after my trans blowing I bought a rebuilt 4l60e online from a guy who builds them all the time apparently.
Anyway, for various reasons I can't return it or contact him for that matter and the transmission isn't working as it should.
I'll list the problems and let you see what I'm dealing with.
When selecting drive or reverse it takes a second or two to 'grab' and almost thumps into gear. Then it's fine...til you select either Reverse or Drive again and it does it again.
The main issue is it doesn't shift properly. It holds gears too long and downshifts at strange points...more worryingly, it rarely shifts into 4th and just holds 3rd in high revs.
Here is the list of the parts used and whether you believe them to be part of the problem;
"Currently has a 4wd output shaft fitted, but I am happy to fit a 2wd one and tail housing at no extra cost. There will be a slight delay in dispatch we hope I swap it over if required.
It has all Alto HEG frictions
Alto red band,
Corvette servo,
extra frictions in the 3-4 clutch pack,
Transgo HD2 shift kit,
all new seals etc throughout. Reconditioned pump, new solenoids and selector shaft switch.
Basically a full heavy duty/high performance rebuild, good for up to around 400hp or heavy towing. Pictures show some of the parts that went into the transmission"
That's the description from the seller, any help or thoughts would be much appreciated.
John
Since you can't even contact him I'd have to say you probably got duped by a scammer. He might have just painted it and shipped it. Did you check reviews or look for complaints against him? Sounds to me like it's a blown transmission that needs to actually be rebuilt. I'm not sure what advice you're looking for but I do feel bad for you. That sucks.
sefiro
Sounds like pressure is low, and/ or the forward/reverse accumulator is leaking or broken.
Did he replace the separator plate - some of the check ball holes may enlargened the old plate of it is still there.
Also, many/most rebuilders will reuse springs and pistons on the accumulator unless they find something broken or are building a race unit.
You can check/repair the above with the tranny in the truck.
Sent from my XT1053 using Tapatalk
rockola1971
Indiana (formerly IL)
Ill have to agree with sefiro. The PCM (AKA Engine/Transmission computer) controls the shifting via the shift solenoids on your valve body. The separator plate which is in between the valve body and the main housing of the transmission. The check balls usually ping the hell out of their holes they are suppose to rest on but instead become lodged and then bad things happen.
Hermans
Hmm sounds like a scam, or this "guy" is just a amateur. Anyway i would go to a official company, and let them look at it. One thing I know is that a automatic transmission is the most complex piece of a car. Sorry to hear!
Chubbs
Hey John.
I feel for you here. But don't lose all hope yet. You posted this a couple days ago; where are you @ on the issue as of now? I hope you aren't driving the truck with these symptoms. If it is in fact a newly reman'ed unit, there may not be a big problem with it but continuing to drive the truck as normal may cause actual mechanical damage requiring another rebuild. Respond with an updated status please
J444HN
J444HN
Hey John.
Hi Chubbs,
I'm not driving the vehicle as I'm not enjoying it but now I know it can cause more damage I'll make sure it doesn't move. I'm quite competent when it comes to cars but not so much with trans but I get the feeling it's not completely scrap. I've just got a feeing that it's something not done right rather than needing a full rebuild.
But as it stands I've not done anymore about it.
Im thinking about swapping the valve body out and separator plate to see effectively remove the Tansgo shift kit.
Thanks for your reply!
Chubbs
Hi Chubbs,
Probably a dumb question I'm sure you checked it out: what was the fill level on the trans' after the truck was up to operating temp?? Did the trans come to you already filled, or did you have to fill it?
Do you have a GM-spec diagnostic tool? Could be some pending codes stored that aren't necessarily activating the 'check engine' lamp.
I'm not going to throw a bunch of suggestions as you have obviously dealt with trans problems before & know a lot more than I do.
I'm just thinking what's easiest/cheapest just as initial troubleshooting before I start cussing out the seller for not returning my calls & emails or paying somebody else to do what I can easily do myself. Have you done any internet searches yet?? Then you could always call a shop that rebuilds 4L60e. Mech's/techs are usually helpful over the phone; most of them know everything about trans', the smartest man of Gods green earth & happy to let you know it by their diagnostics prowess. (Not knocking on any pro trans' guys here, just my overall experience with mech' in general) All you have to do is start off by sharing how much $$ you have spent, state the issue in short, then agree with everything they answer with. You should get an abundance of info that way.
I called a trans shop 2-weeks ago in regard to buying a corvette-spec servo & .490 boost valve; the man who answered was happy to drop everything he was doing for a good 15-mins to share his knowledge & opinions with me. Just getting a couple different guys like that on the phone will give you more than enough info on what to begin checking-out & troubleshooting. Sefiro has excellent advice far as that goes. Always good to do what you can with trans before having to pull it out.
sefiro
I suggest getting a rebuilt valve body with a set of sonnax valves. Also, replace the separator plate with a transgo plate (harder metal). Have! A set of transgo springs around in case any of the accumulator springs are broken. Also good to have, replacement metal Pistons, pins, seals and separator plate seals.
Chubbs
In his original post, there was a copy/paste from the person who sold him the reman' trans stating what was used in the build including a TransGo HD2 shift kit. Is there anything that he should be looking for specifically with that kit if it is indeed there?
J444HN
J444HN
Thanks for the advice so far guys!
I'm going to remove the shift kit I think and put a normal separator plate back in and maybe swap the valve body for one out of a known good trans.
Would one from a 4L65e fit ok?
The 4L60 is a 99 and the 4L65 is a 2003
sefiro
Let's get back to basics before proceeding. Rebuilds happen for 3 general reasons
1) poor maintenance and care
2) product defect failure
3) change of use/spec
For grins sake, let's ignore the first one. For every rebuild you hear about, there is another that is going just fine after 200k, 300k etc.
Product failure: There are some great writeups discussing the various problems with the 4l60e. Under normal, granny use, they never materialize. But if you drive it just so , they show up (check ball hammering, cracked piston etc). When rebuilding these, you might as well build with upgraded parts so the the just so usage does not recreate the problem (upgrade separator plate, metal piston, etc)
For the third category: racing, towing, Jack rabbit, we're looking at some custom stuff to adapt to the specific needs. Custom includes upgraded parts as well as tuning the shift points to match the parts and driver. E.g. Vette servo to hold the band better during towing or racing.
The basic transgo kit ends up bridging both category 2&3. It attempts to easily fix some failing product, and tries to change shift points with hardware. For the weekend warrior, this might work dvr fur you, assuming you are driving it just so, once in a blue moon.
I had suggested the sonnax stuff as it was originally more focused on fixing the product problems, rather than special uses problem. They do have upgrades for special uses as well.
When installing/removing kits, there are replacement parts (ie springs) and modifications(ie drilling). Replaced parts are tossed and modifications are permanent (and may not work well with a item oem part). So, you can't just remove the shift kit unless you have the original parts to put back in. And besides, the original symptom being masked b the shift kit may return when that part of the kit is removed (ie 1-2 bump).
Can you stick a 4l65 valve body on a 4l60 - I'm not a parts expert, but gut feel is no unless you are a tuner. I know builders buy specific year range valve bodies typically.
Steve A
Central AR
What year vehicle did you put the 4L60 in? Is the valve body from the same year as the transmission? There should be a serial number stamped on the passenger side pan rail (i.e. 6KCD XXXXXX), check it to verify year and model. All of the symptoms seem to point to low line pressure.
J444HN
J444HN
I've put it in a 2003 Steve. The valve body is also a 2003 and the 4l60 is a 1999 a second far as I'm aware, I'll check the serial numbers when I get a chance.
What does low line pressure point to in terms of repairing? Valve body?
sefiro
Oil pressure is created with oil pump (transmission removal) there is a valve that regulates the pressure - ~ 80 psi at idle and over 200 at WOT.
Bad seals, worn valves, messed up separator plate could cause loss of pressure. Or a bad pressure valve/solenoid.
A shop should be able to attack a pressure gauge to the side of the case and then use a scan tool to command the solenoid to change pressure which can be monitored via the guage. Recommend this (diagnostic fee) before throwing parts at possible problems.
sonic_the_hedgeh
Check Amazon they have a kit with all the rebuild parts for the transmission. Good news is the kit installs after you drop the transmission pan. I ordered one for my 04 denali that has the 4L65E. It also does the 4L60E.
Less that 100 dollars. Hope that helps
My 04 has 370,000 kms now.
Had the knock valves replaced last year and rebuilt the top end, no oil leaks anymore. I had some blown seals it was sucking in more air and so the computer was just dumping in more fuel. Should have great mileage after the kit is installed.
Sent from my LM-V600 using Tapatalk
wjburken
Eastern Iowa
Ummmm........You do know that you replied to a post from 2017, right?
I want to know what a knock valve is. Also I wasn’t aware a 4l65 could be rebuilt just by dropping the pan. Interesting.
sonic_the_hedgeh
Hi I bought a transgo kit for my 04 Gmc yukon xl. It delays shifts. If you let off the throttle it will shift. It doesn't make noises but seems to downshift fine but delays the shift. I did see someone on here try this kit for the symptoms I have and it worked.
I went to a transmission shop today and they had a guy from the shop test drive. He is saying I don't have a second gear and it is shifting from 1st to 3rd gear.
All I know is it cannot shift into second. He said worn bands but cannot verify. Yet doesn't make sense that someone with the exact symptoms of mine it fixed the problem.
Any ideas? Thinking of getting a second opinion on this.
sonic_the_hedgeh
Sorry that was a knock sensor I was explaining. Bad news my trans needs a rebuild but they guy uses the valvetrain kit I bought. Seems the trans uses one band for 2nd and 4th gear. He verified that it is only using 1st and 3rd which are on another band.
X-ray Nerd
