CB Radio Location
mdnitedrftr
CT
Bumping this thread....
Where are you guys mounting your antennas? Pics?
MadDogDelpho
Texcellent
Doorjam mount right below the driver's taillight. Works great.
TigerEyz3
Slow and Steady
TN
Mine is on the roof...about 18" forward of the 3rd brake light.
TigerEyz3
Slow and Steady
TN
Just remember that your vehicle body is reflecting signal being that close to the antenna. Best performance will ALWAYS come from an unobstructed antenna.
B
bluebear15
wisconsin
I ended up getting the Midland 1001LWX that should be here in the next couple days.
I was planning on mounting the antenna on the drivers side hood corner opposite the radio antenna.
mdnitedrftr
CT
MadDogDelpho
Texcellent
Perfect size. I pulled my console and put in a jump seat so I just threw it in that empty area.
B
bluebear15
wisconsin
mdnitedrftr
CT
What kind of range did they expect you to get with this antenna?
I'll be honest, I'm not really sure.
Although, when the guy was helping me pick an antenna, he said if it wasn't tuned, I'd be lucky if I got 1/4 mile.
B
bluebear15
wisconsin
Does anyone know if there's anything behind the top center pocket between the two power plugs on the center console? Or point me in the direction of how to remove the center console? I was looking to mount the CB there. It will fit in the pocket but just a matter of depth I have to find out.
MadDogDelpho
Texcellent
That whole black plastic piece is just held in by clips, just hold the middle part and you can pull it out. Then you can measure from there
RED TAHOE LS
Rossville, Georgia USA
If you have the full center console, I think a lot of guys put theirs in between the cigarette lighters or right below there. And I've heard good things about Firestik antennas, lots of bang for your buck.
Just to double up on the above statement, my console has space between the front and the dash. I mounted my bracket to the front of console with two (2) screws. The Cobra 25 mounts vertical with the antenna connection on the bottom and sets on the carpet. I used the lighter connection right in front of it. As for antenna, I used a Firestik 3' with magnetic base just behind the front crossbar on the roof rack, and the antenna coax is routed through the front of the l/rear door @ the top. Center of roof is best location, that's why mine is there. The antenna comes with adjustable tip for fine tuning. Good luck
briannorris
