CV spacers vs NNBS CV axles
  • CV spacers
    Votes: 0 0.0%
  • NNBS CV axles
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
MadDogDelpho
Texcellent
I know that after lifting the cv angles get a little wonky, and pull them out of the spindle a bit. The axles from an NNBS are a little longer and I've seen a few guys do it. It's a little more expensive than CV spacers, but I feel like the angle will be a little better with a longer axle. What do y'all think?
slow4dr
Without question, do the CVs if it matches your spacer width. The NNBS CVs are 1 7/8" longer than NBS CVs. I paid $65 each for mine.
I planned on going even wider so I had priced spacers and they were all just as expensive as the new axles.
Cbark2305
I've been thinking of doing a key lift with spacers in the rear. The nnbs would
Fix the problem with the cvs? Wouldn't have to worry about them binding or tearing the boot?
slow4dr
You can't just install the NNBS axles into an NBS. You'll either need a knuckle lift that specifically came with 1 7/8"(+/- 1/8") spacers OR longer control arms. I'm working on the latter for my Wife's Denali.
CamReynolds
Even if you make the axles longer the ball joints will still be wacky
BeenChevy
Minnesota
So you could purchase the upgraded knuckles and keep your balls joints together or The Tuff Country CV Axle Spacers 10805 are an inch thick ~ keeping the axles at the proper plunge depth. Just replace with capable ball joints/upper arms. For the cost of longer control arms, lift knuckles, lift kit? I think this would work for your key application. What do you guys think?
MaBs413
NJ
Do you mean upper control arms only or upper and lower control arms?... I have the upper control arms from cognito... thank you in advance
BeenChevy
Minnesota
what kind of lower control arms do you guys recommend for NBS?
You absolutely cannot fit 1" spacers on a NBS truck with stock parts keyed or not.
Kaeden
What about running these CV Axles with 3" spacers included with a Fabtech 6" lift? Looking for a longer axle solution my self
Nicholas Boyd
Were you able ever to lift your wifes denali. Trying to finish mine up now.
Durobans
