Its like a Tahoe, Only Bigger - 02 Suburban
5dollar
Recently picked this up in PA for $2500.
2002 Chevy Suburban
180k on body
120 on Replaced Engine (paperwork included)
Less than 5k on Rebuilt Trans (paperwork included) - Rebuilt by someone who knows what they are doing. If you're in PA and need a 4L60E tran rebuilt, talk to this guy: https://allentown.craigslist.org/ptd/6174462303.html
2014 Suburban Rims
Interior 9/10
Only a single rust spot on the exterior - no other rot issues.
It does a few weird things, maybe some people could shed some light?
Between 45-55mph, while in final gear, it kind of rumbles a bit, almost like its missing - its not crazy rough but enough that I notice it. Maybe Tune up? Trans was a little low when I picked it up, not by much but just a little - I don't think that would cause this issue.
Howling at speeds above 20 mph from the front. Tone changes with speed, stops momentarily when I let off the gas, then starts howling again - wheel bearing? Its what it sounds and feels like to me. I can feel the "howl" in the wheel while its happening.
Cbark2305
Mine was making noises when I got it too. New front wheel bearing and rear u-joint fixed that. For the rumbling in final gear I'd say start with cleaning out the sludge in the engine. I used seafoam in the gas, oil and through the intake but a lot of people say to use kleen so I'm gonna do that next.
5dollar
5dollar
I am definitely going to do some sea-foam (intake only) and a tune up. Deff wheel bearing looked at sometime soon.
Cbark2305
Little tip if you do the front bearing yourself. If you can't get it out after removing everything them thread a bolt back in a little bit put some extensions on it and crank the wheel till the extension hits the frame. It's basically like having a hydraulic press pushing it out. Very simple
pt1965
columbia,sc
2002 Chevy Suburban
180k on body
2014 Suburban Rims
Interior 9/10
i have 190k on my 2002 yukonxl and it has had what i would call whistling noise coming from trans/drive or rear since i bought it 10yrs ago with 65k on it. i have never replaced anything and the ujoints are still tight, and the rear diff was flushed and refilled 2 yrs ago and it was clean anyway. it has never gotten any worse. i think the rumbling in overdrive is probably a kind of lugging due to low rpm if you have a low ratio diff. i had a 98 z71 that did that unless i was on the highway, so i would lock out the overdrive if i was driving around town. -pt
5dollar
5dollar
Trans bit the dust. Slipping in second after overheating. Bah. Off to the rebuild shop!
5dollar
5dollar
So here is what ended up needing done on the transmission.
Rebuild consists of:
* Reman Pump
* Reman Torue Converter
* New Stater Support in Pump
* Superior Power Valve
* Upgraded Pressure Spring for Pump
* TransGo Shift Kit - Better Flow - New TCC Valve
* New TransGo Harnded Valve Body Plate
* Reman Input Drum
* All Clutch packs Replaced, Performance added Green 3/4 High Energy Friction Clutches
* New Accumulator Pistons (Aluminum)
* New Servo Pin
* New D-ring on Servo
* New Servo Springs
* 3 New Solenoids & pressure switch manifold.
* New Internal Wiring Harness
* New Bushings all around
* High Energy Band
* New Check Bolt Capsule
* New release load springs for 3/4 pack
* Hardened GM Sun Shell
* Rear Planetary (4 Pinion)
* Front Planetary (w/ wide bearing upgrade - more surface area, less fatigue)
* New Input Sprag
* New Boost Valve & Sleeve in Pump
* New Thrust Washers for Transmission
Additional work being done:
* Aftermarket Trans Cooler (13,000btu cooler)
* Glowshift Trans Temp Gauge
* GlowShift Gauge Pod
* Replacing Radiator
* Coolant Flush
5dollar
5dollar
$2700 later, I got my truck back.
Trans Complete Rebuild w/ 2 year 24k warranty, New Radiator, Coolant Flush, Oil Change, Additional Transcooler & Trans Gauge installed.
Take a look at these. This is the 3/4 clutch pack, as you can see BURNT TO A CRISP with NO MATERIAL LEFT.
This is the main front planetary gear - as you can see, the pinions on the gear are BURNT BLACK - thats typically caused by a 300*F overheat.
Sweet Glowshift Gauge
I'm just happy to have wheels again.
2002 Chevy Suburban
180k on body
2014 Suburban Rims
Interior 9/10
I thought the trans had only 5k on it? He should've rebuilt it for free, if he was the original builder.
5dollar
5dollar
The guy that did the rebuild shrugged his shoulders at me. He was a joke. I took it to a legit shop and they found all kinds of wrong doings. Reused, old style parts, stripped bolt heads, stripped bolt holes that required helicoiling, just bad workmanship. I just needed it done, so I bit the bullet and took it somewhere with a great reputation.
What did this guy charge you for the second rebuild?
5dollar
5dollar
$2700. (I took it somewhere else if that wasn't clear. The first guy (who did the work the first time) was a smacked ass) If you scroll back a bit on the first page, you'll see the mountain of parts that went in, I also got the radiator replaced, coolant flushed, aftermarket transmission cooler added (connected WITH the stock cooler) and trans temp gauge added and an oil change. I say for $2700, thats not bad at all.
5dollar
5dollar
Took it back to the Shop yesterday. I took it on a road trip over the weekend and it had a harsh 1-2 shift, they pulled the pan and found the Pressure Sensor Connector wires had pushed out of the connector. They fixed that and put it back together. They say it fixed the hard shift but I'll be the judge of that tomorrow when I pick it up. The gauge they installed also wasn't reading correctly, so they are fixing that as well. All should be good tomorrow.
Ossipeelake
