What am I looking at?
bigfootchiro
Largo, FL
While still trying to track down misfires, I found this tube loose on top of the transmission. First is toward the driver rear of trans, may have been on top of t-case. Second picture is the end of the tube that I found toward the front passenger side on top of trans, just flopping around. Did it break loose?
willxfs
Its definitely a vent line. Cant tell if its hooked to your transmission or transfer case. The black plastic valve looks melted. That bracket should attach to one of the transmission bolts.
bigfootchiro
bigfootchiro
Largo, FL
I can't remember, so I'll have to get under there tomorrow. Does it need to be replaced? I have no idea what it does.
east302
Mississippi
This is what was used on my 1998 front differential, or at least I think that's where it comes from. It's mounted on the driver side near the radiator.
I don't see one on my transmission vent...it's an open end, but would have thought that it would have a vent cap as well.
https://www.amazon.com/ACDelco-25892279-Original-Equipment-Transfer/dp/B005OUQ9LU
The vent has a cap that drops down to prevent water from getting in. I assume that it doesn't take much pressure to push it open to vent.
vsaravia
