95escahoe
Had the tint redone the last shop did a real ****** job (mostly on the cutting of the tint) figured they were local I'd give them a shot since they had good reviews, got my money back on that disaster tho, 20% on the fronts to match the rears, I took that windshield tint strip off looked great but where the tint stopped wasn't the best for eyesight, going to get the windshield done in that 3M film that blocks glare/heat best part is it doesn't darken the windshield
I upgraded my E-fan relays to 80 amp relays and sockets. That harness is a real PIA to rework. Then I washed, clay barred, and waxed with Tri Nova's Liquid Carnuba Wax. And while I was doing that, USPS showed up with my new AC belt tensioner so why not.
95escahoe
Finally got around to replacing passenger door lock actuator. It's been acting up for about 3 months. No more manually unlocking door when there is a passenger! $36 at local parts store. Had to remove and glue original sensor to new actuator.
I need to replace both rear ones they do the same thing from time to time
mals
Western Mass
So after owning my Yukon for one year, it was time to renew my registration and get an annual motor vehicle inspection.
I surprisingly failed for the following reasons:
  • HID Aftermarket Low Beam Bulbs
  • Right Turn Signal Activates Hazard Lights
  • Excessive Play in the Front End
Apparently HID lights that are not OEM have been illegal in Massachusetts for the past three years. So I had to go get a pair of incandescent bulbs and "install them for a re-inspection". The HID lights were in the Yukon when I bought it last year. The dealer I purchased it from handled the registration and inspection, so the inspection station either missed the lights, or looked the other way for the dealer.
I replaced the turn signal flasher relay under the dash with a GM replacement module that is an updated/upgraded unit since this seemed to be a common failure point in '03-'06 models. It seems to have solved the problem.
I tracked the excessive play to a set of worn Pitman and Idler Arms. While I was in there I also replaced the Idler Bracket since it was out and one less tapered joint I had to break, and it didn't look like any of them had ever been greased. After installing them I cleaned out all the grease points on the front end, and greased all the joints until the boots puffed back up. After that I took it for an alignment where they corrected the toe. Overall the job went well, but my arms and neck are going to be sore for a few days after wrestling the old ones out.
If anyone is interested these are the parts I ordered from Amazon. They all worked well, had great fitment, and seemed better quality than the parts I removed.
I also took the opportunity to buy a nice cordless magnetic swivel LED work light. I don't know why I waited so long to get one. I can't imagine doing the steering work without it.
95escahoe
  • HID Aftermarket Replacement Low Beam Bulbs
I also took the opportunity to by a nice cordless magnetic swivel LED work light. I don't know why I waited so long to get one. I can't imagine doing the steering work without it.
The Denali's didn't come with factory HID's in the lows? My Escalade does would have thought the Denali would be similar
Cbark2305
New drivers side exhaust mani in Friday, new water pump and thermostat today
9HOE9
Replaced the parking break shoes since the driver's side shoe pad disintegrated and came apart.. also changed out the headlight housings for new blacked out housings... Next up is new fog lights with LEDs since driver side fog light is busted or new door speakers since they are shot
Sent from my LG-LS993 using Tapatalk
Phlipnstik
