Merc1973
Maryland
While opening the rear glass hatch for the first time, the passenger side hinge came off the glass. I cant be the only one for this to happen... It must be glued i assume. What type of adhesive does everyone use for this repair?
Also both left and right front axle seals are leaking (223k miles) where the axle tubes bolt up to the center section. Is there a write-up on this?
TheAutumnWind
20170614_141039_HDR.jpg Trans cooler upgrade!
Other than the alum angle fab it was plug and play. Much bigger than the old one.
TheAutumnWind
I ordered a few parts for the Escalade today new front wiper arms & hardware/caps, deep trans pan, gasket, filter & bolts all parts are genuine GM
What made you go with a deep trans pan? Your original one needed replacement? I upgraded the trans cooler instead, so just curious really.
95escahoe
Someone put a drain plug on mine and it leaks from there don't want to be bothered with fixing it new pans cheap enough just gonna drop the pan change the filter and top it off and be done with it, was gonna get a PML finned pan but it's the same capacity as the stock pan, my temps are good now don't tow with it so couldn't see spending $200 on that
Drewphil
