Leveling kit, tires, wheels, grill installed- 2015 Yukon
Denton
Waco, Texas
Finally got everything installed, must say I am very pleased how it turned out. Here are the specs:
2.5" SuspensionMaxx leveling kit
285/60/20 Goodyear Duratracs
Chrome snowflake wheels
(stock pic to current pic)
MichaelSE
2010 2500
Tucson
Looks excellent. Completely changed the look of the Yukon. Are you planning to remove or trim the air dam?
Demer
Eagle, ID
@Denton I have to say that that looks absolutely amazing and is exactly the look I am going for!
Now that you've had that setup for a couple of months how do you like it?
Do you have any rubbing?
Did you do anything to the rear of the vehicle?
Did you get your speedometer adjusted?
How does your Yukon ride now vs stock?
Anything you now wish you would have done differently?
Thanks!
Glocksub
Denton-Yukon looks incredible, well done! I'm also interested to hear your opinions on the ride quality vs stock and whether or not you also did anything to the rear......
tomsquad418
Any update on this?
Do your 285s rub? I am doing the 2.5 Suspension Maxx kit and am having trouble deciding in between 285/60/20s, 285/65/20, 295/60/20s, and 305/55/20. I want an AT tire an am considering Toyo AT 2, Toyo RT, Nitto Terra Grappler G2, and their new tire, MT ATs, Duratracs, and BFG KOs. Any insight?
Adam10532
So from what you have written the 2.5 lift in front now has your front end .5 higher then the rear? If so do you have your autolevel consistently on pumping up the rear end .
Glocksub
Based on what I've seen, a 2.5 only on the front is going to put most trucks higher than the rear. I've seen several do the 2.5 frt/1.5 rear with a level result though.
Some with the just the 2in appear to be level but added weight in the cargo area or via a trailer are going to put it nose high.
Adam10532
I would love to do this to my 2016 Yukon Denali XL but I would also like to do a one-and-a-half lift in the back but from what I've seen I can't find a company that can compensate for the added length needed for the arms that activate the autoride system
tomsquad418
Adam10532
supermaxx will sell you just the relocation bracket needed for autoride and magnetic ride ask for john he will help you out
Denton
Denton
Waco, Texas
Do you have a better side shot and picture of the back? How do you like the tires? Do they look too skinny or is it enough width? Thanks
Sure, what angle do you want exactly and I'll get it today. Love the tires, best set I've owned yet. Not too skinny at all, look meaty.
Sent from my SAMSUNG-SM-G930A using Tapatalk
tomsquad418
Can you please take a few pictures from the side, then one of the rear and one head on? Plan on doing this same setup on my Tahoe with open countries ats in this size. Wish Nitto made this size..
tomsquad418
Any update on the pics??
Redbeard1
2016 Denali with SuspensionMaxx leveling kit 1.5" and 33x12.5" Nitto Ridge Grapplers.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jennabear the denali looks badass, I would like to know if you are running 33 x 12.5 or 305 55 20, and also are you having rubbing issues or how much trimming was involved. I was under the impression that quit a bit of trimming is in order to run 33's without 4 inches of lift.
JennaBear
Resident Ninja
San Diego, CA
They are 33x12.5x22 which is actually a but wider than 305s. With the 1.5" lift, I do not have any rubbing.
Sent from my SM-G950U1 using Tapatalk
Vor3001
JennaBear - Great ride.. Was wondering since your lift is only 1.5".. in your opinion, if you did NOT do any lift and left it stock would it rub?
assuming you did not trimming in your set up?
tks!
JennaBear
Resident Ninja
San Diego, CA
I do believe it would have rubbing issues without a lift on there. You are correct, I did not have to do any trimming on mine.
veteran111
