Need more rear lift
Brian1971
Looking to add 1 inch spacers to mine soon. Did a 2 Inch leveling kit and now back is a bit lower. Hoping one inch will not affect the autoride option.
AppocAlexx
Darth Appocalexx
Abilene TX
even if it does they make an extended linkage for them, do some searches for the autoride lifts and you will find the solution. I'm pretty sure its a cheap and easy mod for the guys that do it, but don't quote me on it. Just check it out you may be surprised.
dirtydenali07
How much more lift will you get if you swap out stock rear coils with Z-71 coils? I just picked up a set for my 07 Denali XL because the air ride doesn't work and the wheel well measurements are the same(36.5"). Looks like rear is lower, and when we travel it does sag.
Dillon2222
when installing the spindle lift, did you run in to any issues with the ABS harness being to short?
Bentley95
