Changed the oil and the wipers and checked fluid in prep for a 500+ mile trip.
then I backed off my ramps and forgot I left the bucket under the truck, and dumped all the oil all over the driveway :worthy:
in other news, the power steering leak looks to be near the booster, either that or its just leaking from everywhere. I cleaned up underneath to see if I can pin-point an area.
That's something I'd do! :nolol:
Did the big front brake nnbs upgrade with braided lines and fixed the blown rear line. Also had to replace one rear caliper. Stops great now. View attachment 80941 View attachment 80942
It's hard to tell in the pic without the old rotor next to it for comparison, but the size difference is huge Imo. Stock size looks puny compared to the nnbs rotor.
I got my A/C recharged today after replacing both Schraeder valves yesterday. I had completely discharged my system when I did my EGR delete this week and broke 2 bolts on the exhaust manifold; I had to remove the hoses from the compressor to get to where I could drill and tap new bolt holes. Perfect time to install those new valves I had laying around since last summer when the idiots at Jiffy Lube recharged my system and then told me my high side valve was leaking. I don't know why they recharged it if one was leaking. Hopefully this time it will keep working longer than a month.
W8TVI
Traverse City, MI
Bask in the glory glare of my LED fog lights, DRLs, and switchback turn signals!
I re-installed my LED switchbacks.
I almost want to replace my DRLs with turn signal sockets and put another set of switchbacks in them...
Boxdgm
MN
Yes it was time. wiped everything down after i finished but should have retaken the picture.
Drewphil
