bottomline2000
Dallas, TX
Woah..missing the party..hopefully she's up and running soon!
It wouldn't be so bad if there weren't 5 of the type of bolts that you hope you never have to do again. Think of spark plug #8, then put it around the back of the block where it's even harder to get to and impossible to see so you have to do it totally by feel and it's all you can do to keep from dropping it as you hold it between 2 fingertips, and then make it 5 of them. And then find out someone gave you the wrong plugs so you have to remove all 5 again and reinstall 5 new ones. As well as remove a whole ton of other shit just to get to them. The tops of my hands haven't had a chance to scab over the places that keep bleeding and there's no room for gloves. Waaaahhhh. :signs8:
1992rs
OR
Red I just checked and my line goes from tb to passenger side valve cover like the 03+ guys. I wanted to snap a pick, but I just got home and my engine and covers were still roastin.
Thanks man. I have that figured out now.
Well today I set my sights low, I just wanted to remove the blower and intake manifold off and reinstall the manifold with the gaskets. While pulling the manifold off I forgot to disconnect the IAT extension harness and the wires pulled right out of the Delphi connector. I Youtubed how to remove the pins, then pulled them out, soldered the wires on and reinserted them, then checked the resistance between all the pins on the IAT sensor and again after reconnecting the extension to it. I'm not taking any chances, and this is impossible to reach after the manifold is installed. Then I used Permatex gasket sealer between the gaskets and head and reinstalled the lower intake manifold. I feel confident there will be no more leaks. Tomorrow I'll reinstall the blower. I have pics of the remainder of the install from yesterday and I'll post them soon. Hopefully I'll get it running right tomorrow.
Getting close again. The anticipation is killing me but I'm trying to take my time.
about20ninj45
You think it'll fire this time? How much work do you have left to do? I'm rooting for ya!
VDV18
Just read through all of the posts with the Whipple.....hope it fires up later on today! :waytogo:
about20ninj45
atta boy!
we need a video of your first impression, like a reaction video!
Fosscore
:chewie::chewie: woohoo....way to go man. Look forward to the videos and first reports!!!
I'm still taking it a bit easy but I did hit WOT a couple times. I had to data log and email the file to Justin @ Black Bear so he can analyze it and make sure things are a-ok. He said better safe than sorry lol. I can tell this thing is pretty damn quick though. The sound when it hits about 5000 rpm's is awesome!
X-ray Nerd
