Finally!!!! 2/4 belltech from NorCal
lynxnova
New Jersey
I finally got the lower my truck.... it's a 2/4 belltech set up... strut cups in front and springs, sway bar end links in rear... waiting for the rear to settle a little more before I decide to cut autoride endlinks to lower the rear maybe half inche more....
. The only thing that bothers me now are the factory escalade 22" wheels...lol. Now that it's dropped the wheels look a little to small... thinking on selling these wheels and upgrading to 24"..
juan84
Mounds view MN
Looks good ! I need to install mine on my nnbs just sitting waiting for time to cut out the bump stops
sent from galaxy s6
Oakley125
Looks awesome! My opinion is yes, def go to 24's and no, don't lower rear any further. A tiny bit of rake, like yours, looks just right on this truck body.
Too low in the back and your truck starts to look like you've got an overloaded trunk...kinda goofy like reverse rake
L
lynxnova
New Jersey
Thanks oakly125.... I'm planning on leaving it like this... I don't mind the little rack look...
Msalinas408
Looks good man! If you do end up getting 24's make sure you get 305/35R24 tires. This tire size will help maintain a smooth ride.
2016YUKONSLT
looks good! I get so many compliments and looks with my 24's and the drop.
did you notice any improvement with the larger sway bar?
L
lynxnova
New Jersey
@2016YUKONSLT... thanks man... I didn't get larger sway bars only the end links but it rides just as good as factory.... if I'm slightly turning at high speed and hit a little bump the tail does feel like it sways a lil so maybe getting a stronger bigger sway bar would help with that.... factory set up did the same things also... the sway bar on these things suck
EzSkAnKeN
Damn! I've always wanted lifted rides, now seeing this my thoughts have changed.
Would have to be installed at the dealer so the warranty won't be voided, but damn that looks good!
Drewphil
