TXBowtieGuy
As soon as I finish my coffee I'm going to install my 3" keys and 3 " spacers for the rear. I'll post b4 and after pics.
It def sucks if they've never been removed.Good luck!
If your keys have never been removed, you will be fighting it for hours.
I ended up cutting the bottom of the cross member out to drop the bar and key together then separate them on the floor using a 10lb sledge.
What blocks are those?I found the jack stands everything fell apart easily. The underside was very clean and the keys were stock. I have a question though and it may seem stupid but here goes ... the blocks for the springs in the back do they go on top of the coil spring or the bottom? I am sitting here with the rear end of my truck taking apart as we speak ready to put them on the.
Fairly certain they go on top of the springs.
What blocks are those? View attachment 79989 View attachment 79990
Mine is an 03. I didn't read your entire list, I didn't know you were lifting. I actually dropped mine.What year is yours? Those bump stops are different from mine.
The blocks go on topWhat year is yours? Those bump stops are different from mine.
Looks good. IMO I think it would look better if you cranked the keys just a little more. Maybe another inch in the front
