05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,244
- Reaction score
- 11,648
I never met anyone who's had worse luck than me till I met @Bigbeardenali1992
This is my struggle everyday
Aww that's messed up haha. Well turns out the diode was the culprit after all. I just did a quick look this morning on my way to work and it was fine from the top side. This evening I pulled it out and it had burned out. Cracked across the bottom the diode. So new one in and everything is back to normal.
Aww that's messed up haha. Well turns out the diode was the culprit after all. I just did a quick look this morning on my way to work and i5 was fine froM yhe top side. This evening I pulled it out and it had burned out. Cracked across the bottom the diode. So new one in and everything is back to normal.
At first I went with a smaller 1A and it fried after only a couple days. It was alao really small in size. So I went with a bigger 1.5A and that worked fine for the last 2 months or so. Not sure why this one all of a sudden went. I will havw to keep an eye on this one and see if it presents any issues. Never a dull moment with my truck.....I would guess that the diode you used might be too light duty, but it really shouldn't take much to just activate a relay.
If you are using a really small diode, you might want to go with a larger one.
32 volt, 1 amp should be good enough, and I think should be easy to get. Most relays that side shouldn't draw anymore than about 500mAh to activate.
At first I went with a smaller 1A and it fried after only a couple days. It was alao really small in size. So I went with a bigger 1.5A and that worked fine for the last 2 months or so. Not sure why this one all of a sudden went. I will havw to keep an eye on this one and see if it presents any issues. Never a dull moment with my truck.....![]()
1.5 amps is pretty small. Not sure what it takes to turn on the relay but it might be close to that.At first I went with a smaller 1A and it fried after only a couple days. It was alao really small in size. So I went with a bigger 1.5A and that worked fine for the last 2 months or so. Not sure why this one all of a sudden went. I will havw to keep an eye on this one and see if it presents any issues. Never a dull moment with my truck.....![]()
Good to know! I'll ha e to look into this week's and have everything measured out to see if it's drawing right and then put a diode in accordingly.If the one you selected is too low of voltage, you can still burn them out.
When I did my dome light mod, I measured the current being drawn by all three LEDs, and it was only about 400mAh, and I happened to have a couple of 32v, 1A diodes in my parts bins.
32 volts and 1 amp should give it enough it more than enough in my case.
One thing to remember is that those diodes will heat up. If it is already hot where it is, you might need to go bigger still to make up for the extra heat.
If you have a meter that can measure amps, you could find out what the relays are drawing through the diode, and then find one that doubles whatever it is drawing (That is why I like to choose the 32 volt diodes).
Something to remember when using the amps range on your multimeter, most meters don't use a fuse on that range, and most cheap ones are only good for 10 amps max. Make sure you are measuring the right side of the relay, or if checking something else, that you KNOW it won't be drawing any more than your meter is rated for.Good to know! I'll ha e to look into this week's and have everything measured out to see if it's drawing right and then put a diode in accordingly.
Other wise you'll let the magic blue smoke out of it.![]()
It's letting the soul out of electronics, without it they won't workI see what you did there...
Where were you going that you passed mammoth? LolCrazy I just passed by there just back in January. I waved to you as I passed by lol.
Oh wow what a small world haha. Yeah you went right by big bear! LolTook the back way from LA to Palmdale to Victorville on our way to our final stop in Vegas.
You were washing your truck with nothing on? Neighbors must have loved that.![]()
