Megan the Tahoe
gtrslngrchris
I picked up this Tahoe the first weekend in February this year after deciding I'd buy and build a Tahoe for the same money that my Duramax was going to cost me in maintenance this year. That way I can push off the maintenance for more fun things and get a new daily driver out of it that's slightly less annoying, but also a lot slower :(
I talked the guy down to $3500 because of some door dings, hail damage on the hood, pretty minor hit on the rear passenger quarter and the rear wiper pushed in slightly along with possible water pump, serpentine belt and a few other minor things. That said this was a 2005 LT with everything but the sunroof so I was pretty stoked. This is how she sat after I drove her 3 minutes home.
I did almost nothing the first week other than drive her to and from work but as soon as Saturday rolled around I pulled the interior completely as the previous owner had absolutely no problem living in their own filth in this thing and letting their grandkids do almost as bad in the back seats. Lucky for me I had a coworker's son who was in trouble that had to help :D
Keep in mind this is AFTER the first vacuuming pass but right after I pulled the seats.
Once all the seats and console and plastics were out I yanked the carpet and we then marveled at how they managed to get so much crap underneath the carpet and jute padding.
Then it was time for a light round of sound deadening. I wasn't interested yet in pulling the headliner and door panels to do a complete job but while we had most everything else ripped out for cleaning it seemed like the thing to do. FatMat 80mil first always. Here you can see Adonis enjoying the pain in the ass that is making the FatMat fit all the contours and look pretty.
I say I did nothing the first week but I did go get these off a 2016 Silverado in my Duramax. I paid $650 for the set with trashed tires and managed to sell my factory wheels and tires for $600 the next day. I had a set of 265/60/20 10-ply tires hanging around from my Duramax still so I had my friend mount them for me and then Adonis got to learn how to use a jack and torque wrench :D
Once we got done with the distraction of the 20s it was back to real work and so we took the carpet to the car wash after doing some pre-treating with Simple Green and a good deal of hand scrubbing.
Then we let them drip dry in the tailgate for about 10 minutes and then drove back to let them air dry in the driveway overnight.
Once the carpet was drying it was back to sound deadening and the second layer is always a decoupler. Closed cell foam went in to keep sound transfer from happening between the FatMat underneath and the mass-loaded vinyl that would go next that actually blocks the noise.
Finally we sat in the garage and did a thorough cleaning of all the interior pieces that were strewn about.
That was most of weekend 1 done and I let it sit and drove other things the rest of the week. I installed my Pioneer 8200-NEX at some point using the PAC interface. Normally I would use the cheap harness and bypass all the factory systems but I'm not going to replace anything for awhile sound system wise... not exactly anyway.
For weekend two one of the first things I did was to re-clean almost everything because by the light of the garage it had all looked clean a week ago but in daylight that was another matter entirely. Lots of stains and spots that were just hard to see in bad lighting. Next I attacked my new wheels again. I had re-used the factory lug nuts that are designed for the threaded nut center caps but I found a set of the new 22" lug nuts on eBay used for $37.50 shipped with wheel locks, key and the documentation so once they were in they went on and the wheels look much better for it I think.
Next was debadging the whole truck including the body side mouldings. For the badges I usually hit them with a head gun to soften the adhesive a bit then run behind them with fishing line to cut through it and then off they come. For the side mouldings they get a lot of heat gun and then I start with the fishing line enough to pry the edge up and then they pull off pretty easy working top and bottom back and forth basically just tearing them off gently.
I also modified the factory Bose subwoofer to run on a separate amp which is a mod I've done before with great success. The factory system to me sounds like shit and I've narrowed it down to two things. 1: the Bose amp is underpowered for the application and 2: the headunit/source is garbage. I already had replaced the source with a top end Pioneer unit and the system sounded much better already but the bass could still be better so I tossed a $50 Boss amp in the back and wired up the Bose sub to it.
I clip the connection from the sub to the amp and then connect White with Green Chaser to Red and then Green is my Positive connection to the amp and White with Red Chaser is my Negative.
Because I wanted to be fancy and because I know I will definitely be removing the console more than once after this I crimped on a plug so the console would remain modular. I wouldn't normally crimp my connections but on a setup like this I'm not too worried about it and it's not too unlikely that it will be temporary. That said, this will make my life infinitely easier in the future.
I finished that night with wrapping my bowtie in carbon fiber finyl I had laying around. It seemed like it would go better with the Spiral Grey than flat black and to be honest it grows on me the more I see it.
Most of Sunday for weekend 2 was spent cleaning and reassembling half of the interior so I could drive it again. While I was cleaning interior pieces and reassembling my friend was hitting the adhesive on the doors with the rubber eraser wheel and then doing a light polish to see what the paint would look like after a bit of attention. HOWEVER, it did get exciting after we got back from test driving an M5 because we decided it was time to install the Corsa 14232 exhaust I had bought. Unfortunately I didn't take any pics of the install or even a shot of the tips while they were shiny and new but I do have this lovely picture of the boxes.
I also had my friend take a video of the exhaust note. I absolutely love the way it sounds and compared to my Duramax it's whisper quiet on the inside. It's actually very surprising to me how there is absolutely no drone with an exhaust note like this but don't worry I'm sure to ruin that soon with what is coming soon.
We managed to finish that just as it started raining so we went and drove around and did stupid things in Tow/Haul in the rain for a bit to enjoy the exhaust.
Hopefully some of you guys will enjoy my build thread. This is my first Tahoe but I've owned many 99-07 Classic trucks before and have a pretty extensive record of modifying them. Here is a link to the other GMT-800 I currently own which is a Silverado front end swapped to a Sierra Duramax 2500HD with a big turbo and built trans and way way too many other things to list. Should give at least a few of you some ideas for things!
gtrslngrchris
gtrslngrchris
Since last weekend I managed to get a tiny crack in the windshield filled and then put on some new tail lights. I'm not the biggest fan of the straight LED replacement tail lights so I went for these which look like the NNBS tail lights but I can put my own LED bulbs in.
I ordered headlights and turn signals for the front but they shipped me the wrong version that had orange reflectors so I'm still waiting to get that resolved.
Tonight I replaced the third brake light that was dead and I finally got around to finding a home for the amp powering the Bose sub and taking inspiration from the Denali guys I decided it was going to live in the rear cubby.
While it was more than wide enough it wasn't deep enough BUT there was enough clearance behind the panel so I just cut a giant hole in the back which also gave me easy access to route all the wiring through.
Here you have the mostly finished product. I ordered some 90 degree RCA adapters that will let me close the lid and I have the amp held in place by heavy ass velcro. This means with it in the cubby I can still get to it and adjust settings or remove it altogether very easily.
Finally I finished tonight by completely reassembling the interior for the first time in nearly 3 weeks and it feels amazing.
BADRIDES
Show me those tail lights lit up in daytime and night time.
Cattivo
The Concrete Jungle
Great job brother, I need to rip my filthy carpet out as well... did you run into any problems removing the carpet? any special tools I need? I've replaced carpet on a few trucks before just not a Tahoe
gtrslngrchris
gtrslngrchris
Pulling the carpet on these trucks is about as easy as it can get even if you don't want to pull most of the plastics since you can shove/wiggle it back into place without ever removing most of the trim. Once you remove the seats and console which you just need sockets for you can just pull the carpet up. The only questionable part is whether you unbolt the dash support in front of the center console on the driver side or just cut the carpet. I've always just cut it as it doesn't hold the carpet in place and it's about a 2" section you're cutting that you'll never see. There are a couple of plastic retainers under the front seats but they just pull up and are attached to the carpet itself like the rear plastic pieces for the 3rd row.
I think this is the 4th GMT800 I've done this kind of clean on and it's much easier than any other vehicle I've done the same to.
RED TAHOE LS
Rossville, Georgia USA
Chris, welcome to the forum. Your determination is off the charts, and it shows in how well you have transformed this animal into a BEAUTIFUL CLEAN RIDE, job well done. I don't even want to guess what the co-workers poor kid did to be put through this, but I hope you gave him a very good tip. Good luck to you , glad you joined us.
David g..................:)
jarydM
Lost in the Woods
Tennessee
welcome to the forum, looking forward to what you're going to do!
gtrslngrchris
gtrslngrchris
I was pretty lazy today as it was colder than I wanted it to be so I didn't do much at first other than swap all the interior lights and my puddle lights over to natural white LEDs. Not too blue, not too yellow and of course no pics of that because boring and because I forgot.
I got bored doing nothing all day though so I went out to the garage a bit ago and decided to hardwire and mount my radar detector. I used the SEO ACCY fuse in the driver side fuse panel and ran the remote mute button up underneath the steering column. Wiring ran up above the headliner and hidden right next to the mirror harness as it comes down the windshield.
Next I decided to finish up my headunit install by replacing the passenger side cigarette lighter socket with a combo Aux/USB port.
I did this on my Duramax as well but this time I decided to think ahead and make it modular like I did with the sub and so I bought two 1.5ft extensions so that when I remove the center console I can unplug from the dash instead of having to remove the headunit and unplug there.
With everything plugged in above I decided to test BEFORE I installed everything which is backwards of how I normally do things and so you can see both iPod1 and 2 lit up as well as AUX now, success!
Next I notched the center console behind where the top face sits so the wiring can run up easily to the dash.
Then my Knipex cleared the rest of the way.
And finally the finished product!
jarydM
Lost in the Woods
Tennessee
Love it! Pretty much exactly what I'm going to do, except I'm removing the cigarette lighter on the driver's side for it.
Which pioneer head unit is that?
Never mind... I see that it's the AVIC-8200NEX
gtrslngrchris
gtrslngrchris
Yep, I love it. I have the 8000 in my Duramax. They're pretty close to identical but have some minor quirky differences being two generations apart while still identical hardware.
Today my friend and I started in on the install for my remote start and as everyone knows step 1 for remote start install is longtubes so you scare the shit out of anyone close by when it starts up out of nowhere :D
enigmaspeed27
