DDenali
Orangeburg, SC
That's the thing, gauges look cool but for the price of this setup and what it can do... you just can't beat it and you don't have to hack up the center console, they have all kinds of different external mounts.
Thanks man and I will get some pictures of the mount but basically you have to hack the shit out of the plastic behind the bezel and then cut out the bezel itself which is all easy to do but there is no turning back.
What you are trying to do is mount a thick flat piece of metal or thick plastic behind the bezel with screws or bolts, then attach the tablet to that and that can be accomplished a few different ways, heavy duty double sided tape, velcro or brackets.
I am still working out the kinks right now because I am getting my power from the stereo USB and since you cannot reach the power button on the side you will need a Bluetooth remote, they make very small compact ones cheap.
I am also going to hardwire the kindle to clean it up as well.
I will send you some pictures shortly.
Thanks bud I actually have an extra bezel thank god lol but like you said once your committed that's it. But now the dilemma your Nali is 03-06 mine is a 02 my bezel is different I'm gonna have to see what I have to do
Fosscore
This exhaust is coming off. I have the proper manga flow cat back. But keep getting delayed putting it on. Not sure if I like the big tip that comes with the kit , may put the corsa tip back on after.
That should sound good. Let's see a comparison of the tips.
95escahoe
Interested to see how the Magnaflow sounds debating that or the Corsa setup
ScottyBoy
Shreveport, La
@ScottyBoy usually has a harness or two laying around. He also makes them.
I don't have one right now. And I don't exactly "make" them. What I do is I pull the fan harness wiring and relay box from a truck in the junkyard and completely clean all the wires and pigtails, and wrap everything in brand new wire loom. So basically I refurbish them but I don't make them. They are somewhat rare since they are only on 05-06 half ton trucks and SUVs, so every time I see one in the junkyard I pull it.
05Single
afraid of the dark
My bad :okay2:
DDenali
Orangeburg, SC
Was window shopping grilles and found this one
https://www.carid.com/2005-chevy-tahoe-grill/royalty-core-rc1-classic-design-grilles-258939254.html
I'm just confused on the price :shakehead:
not exactly but it's close
05Single
afraid of the dark
Been seriously thinking of getting that exact grille lol. But I would ptm the border, which seems that nobody does with those style grilles:confused:
ASG-MikeS
