Yukon Down, AWD delete, headers, converter etc...
01ssreda4
Yes, stock crossmember would need to be from a truck that came with an 80e originally, like maybe a 2500 suburban?
subieworx
So then there won't be any issues with the ECU controlling the 4l80 over the 60?
bottomline2000
Dallas, TX
Or you can drop some weight and get a cool custom one from the guy on pt.net
Also need a different flex plate/converter and shorten your driveshaft. We should have had that trans stock.
Smoke Em All
Taylor,Texas
Out of curiosity is it possible to pull the front drive shaft without any issues? I'm pretty sure my front dif is starting to make noise and I had planned to pull the cv axles for sure but if I can just pull it all out and temporarily leave the transfer case that'd be awesome.
01ssreda4
Yes you can on a selectable 4wd/2wd transfer case. On a fulltime AWD setup like the denalis and escalades have you cant, it wont drive properly.
Smoke Em All
Taylor,Texas
Well that's good to know mine is selectable. Most likely I'll be pulling everything but the transfer case this weekend. Also as far as the selector on the dash. Does that need to be tuned out or how does that work. The reason I ask is that I recently had it unplugged and I was receiving a service 4x4 message on the dash.
Smoke Em All
Taylor,Texas
Did this yesterday. Only issues I've encountered so far are the annoying service 4x4 message and the cv axle was holding a trashed hub bearing together so I replaced that.
Any ideas on how to stop the service 4x4 message?
01ssreda4
What all did you unplug? Did you remove the transfer case or is it still in the vehicle?
Smoke Em All
Taylor,Texas
Only removed the items in the pic. Transfer case is still in there for now. Only one plug that went to the front diff.
01ssreda4
That one plug on the diff is whats causing your issue. The Denali diffs have nothing to plug into them.
Smoke Em All
Taylor,Texas
Well it's all gonna go back in now lol. The diff wasn't my problem it was the passenger wheel bearing. I also posted about losing the driver bearing on the "what did you do to your gmt800" thread.
yukoncornelius84
Hey bud have them wheels come off yet and hurt anyone? Hope your not towing when it happens! Why do I get the feeling we will never know even if they do come apart:D
yukoncornelius84
I love your build but how can someone with that much know-how overlook something so critical. Of course the shaft tightens down on the same piece of metal in the hub. Otherwise we would have some friction, no? The problem lies when the wheel bearing decides to fail there is nothing stopping the wheel from separating from the vehicle. A stub shaft will not let that happen. Just do it.
01ssreda4
So I decided I wanted a little more performance, and towing prowess. I ordered some blue box Motive 4.30 gears, part number GM10-430 and a Ratech rebuild kit. I also ordered a Ratech solid pinion spacer. I decided a new cover would be nice also.
Motive gears and cover.
Opened it up and found an open differential. I wasn't too thrilled about this, I figured it had the g80 locking diff. Only thing I can figure is because it was full time awd they skipped the locking diff.
Found a buddy who had a g80 sitting in his garage across town. So I drove over and got it. Here I was passing The Strand Theatre, it is an old and decorative building. Apparently I was missing the concert.
Here's the g80 and the stock diff:
Basically there are two bearing sizes for these diffs. The problem is its not just the diffs that are different its the actual housing that's machined bigger. So the deal is you have a small bearing that mates with some diffs and housings, and a larger bearing that mates with other diffs and housings. You dont know what you have until you measure it. The s10 the g80 came out of has the small bearing, and my housing is machined for the larger bearing, and they dont make a bearing that will make it work. So, back to open diff I go. I set the gears up for those interested at 10 pinion preload with no seal, 20 with seal, and 30 with carrier and backlash was about 5/6. I used a 40 shim under the pinion bearing and the pattern was perfectly centered and egg shaped, no hard lines. I was very happy with how these gears went together. I did have to bend the stock panhard rod slightly to clear the cover since its larger then stock.
Driving impressions: light throttle acceleration is very easy, motor never works hard, the converter tightened up its manners and feels really close to stock at light throttle. Hwy cruise it accelerates easily without unlocking the converter. And the little bit Ive rolled into the throttle the rpms climb really quick. Cruise rpm is about 2500 @ 80, and climbs up pretty quick from there if you increase speed. The truck is on 31 inch tires.
albac
