Double DIN head unit...who has what
Bonestock
Got an 03 Suburban with no xm but with bose speakers. No aux is one of the first things I'll change. Been reading on adding etc but it seems that to add one without tapping xm is going to run about $100. I'm trying to see who is running what HU that also controls Spotify and or maps. I'm using an iPhone 7 so Bluetooth it is. I use my phone for gps so that's no important at all in the unit. Post some pics and let's talk about it. I know nearly nothing about what's out there in the aftermarket either so I'll be learning as I go. I know there is a wealth of knowledge on this board so thanks in advance to all!
03YukonNH
Manchester, NH
I'm on my second Pioneer AVH model. The only reason I switched from the 2012 AVH-P4400BH to the 2016 AVH-X5800BT is for XM. You can buy a SiriusXm tuner (SXV300) that will plug right into the back of the head unit. The radio also has spotify and Pandora on it that will integrate with your phone on the screen via Bluetooth or usb. Also, if you can get it to work, they have AppRadio which will display your screen on the radio face. I say that because it doesn't work with my Samsung s7 edge. Iphone may work better. In my experience Pioneer is the cheapest option for a double DIN radio and I have never had a problem.
As for the XM antenna, I removed my onstar antenna by dropping the headliner, which gave me access to the bolt holding the antenna in place. I disconnected the two coaxial lines from the antenna and hooked up the blue coax to a buick rainier xm antenna I found on ebay ($20). That xm antenna will go right in the hole in the roof the onstar antenna left behind. The xm lead from the buick antenna is the orangy brown one. You can then find the other end of the blue coaxial wire under the passenger side dash by simply dropping the glove box out of the way. It is plugged into the onstar module under there. Unplug it and remove the blue outer plastic shell then plug it into the Siriusxm tuner. It was a good solution to make the roof still appear factory and not use the magnetic xm antenna that comes with the SXV300.
YukonXL04
The Riverboat
Arlington, TX
I second pioneer. Have always enjoyed the ones I have owned.
Currently have a avh4300 I'll be looking to replace sometime in the future just because it doesn't have bluetooth.
Also have a avh5700 that does just about everything I want it to do, android integration could be better though.
I think you get the most bang for buck with pioneer. Also like kenwood. Not really a fan of jvc or sony
B
Bonestock
Thanks for the replies. Seems pioneer is the way to go. Local store tried sell me a Kenwood exelon that was $899 plus $150 for a harness and $200 for install. What harness will I need? $150 sounds like a lot
mals
Western Mass
These are the items that I currently have in my Amazon cart:
I haven't pulled the trigger since the MVH-AV290BT is the only BT unit in the Pioneer lineup that doesn't have integrated control of Pandora and Spotify. Really this shouldn't matter since no previous head unit I've use has had that feature, and I've always managed to play music or podcasts directly from my phone via BT audio. Knowing that I could have that feature in the Pioneer AVH-X3800BHS makes me want it, but I don't need the HD or Satellite Radio option, nor would I ever use the DVD/CD slot, so it's hard to justify the bump in cost.
jerryjoe28
That Guy
cabot AR
guess ill come in here and go a totally different direction lol ....... i ave a JVC KWV420BT. i love it. it is the first non Pioneer head unit i have ever owned. when i was buying a few months ago i just assumed i would get Pioneer again. after messing with a pioneer that a buddy of mine has i wasn't impressed with the EQ adjustment. after talking with @yates ™ about it i decided to check out JVC. i love this thing! blue tooth, Pandora, back up camera, and a full 7" screen. i wouldn't hesitate to buy another
jerryjoe28
That Guy
cabot AR
if you want to see exactly what i did/bought click the "04 crew cab link" in my signature. i think the radio starts around page 19-20
mals
Western Mass
How's the Bluetooth pairing? I have a JVC single DIN media unit installed in my wife's car. BT is slow to pair, sometimes only pairs the phone, sometimes only the audio, sometimes it needs to be power cycled to connect properly. I had seen similar reports of slow pairing on newer units, so I just stopped looking into it and moved on.
mals
Western Mass
I can't see your sig for some reason.
If you are on a mobile device, turn your phone sideways. There is a different mobile layout depending on if the view is portrait or landscape, and for some reason they display different things.
jerryjoe28
That Guy
cabot AR
i never have any problems with the phone paring. the only thing that does bother me is if i was listening to Pandora when i turned the truck on. for some reason when i start it back up the "info" wont display on the screen. it still plays and works just no info? its a simple fix just swap to any other input (i usally just hit the tuner button) and click back on Pandora and its there. not sure if it is the head unit or my phone.
B
Bonestock
Thanks for the replies. Looks like doing this myself I can save about $600! Love this forum!
jarydM
Lost in the Woods
Tennessee
I'm looking to install the Pioneer 3800, with a back-up camera. I want the DVD ability for the significant other to watch a movie on long rides, and being able to sync my phone display to the headunit for nav is also important.
200$ I'll also consider the brand new Sony, which seems to be pretty good.
MikeW
Jacksonville, FL
I put in the Jensen VX7022 DD - does everything. DVD, AM/FM, Bluetooth, Nav etc. Added back up camera and XM. All configured for it. Figured the ol' gal (02) has 276,000 miles on it - didnt want to put in a $800 unit. Think it all came to $350. Good luck!
HeavyHoe03
