How many miles you guys got on the odometer?
K
Kingx1
I have a rough idle still but my dash ain't lit up like a tree. I don't wanna throw parts at the truck either, but I have 173k on it and I'm sure they're the stock coil packs in mine. Might be what I get next. Glad those things fixed your truck....I'm hoping itnfixes mine!! Thanks for the links by the way....too bad I have a 6.0L or else I would've clicked buy lol
93blkongreenpro
VikingTrad3r
I put a down payment on that one while I was waiting to get my insurance situated. I have a lot of points on my license and I explained that to the guy I was buying from. He said that if I couldn't get insurance he'd refund my money. So I found this other one in the meantime and I jumped on it.
223000 miles 2006 white denali xl
carrier bearing, trans (from the oem trans cooler/rad failure not the 4"60e) , water pump, oil pressure sending unit, oil pan gasket,
225k on a 01 runs strong last one was a 02 and had 295k on it and it ran like a top
. why did u gdt rid of the first one (wreck?)
Boostedlsx
No wreck just needed truck bed for work so had to sell it body was rough anyway
VikingTrad3r
Up to 273k on my 03 5.3L. Replaced the transmission at 250k. I regularly send oil samples to Blackstone Labs and it has a clean bill of health.
when you send it to Blackstone, do they take into consideration the oil that you use? I use Quaker State Defy which has an elevated zinc level compared to most oil's that do not. Just wondering if they would take that into consideration? Do they ask you for your oil that you typically use?
03YukonNH
Manchester, NH
Yes they do. I used to use Castrol High Mileage and they would always mention the sodium being a little high (usually an indication of coolant in the oil/head gasket problem) but they said it was actually an ingredient in the high mileage stuff. I guess it acted as a detergent or something. Anyways, since I switched to mobil 1 synthetic the sodium levels dropped right off and they said that was to be expected since I switched.
Nealboortz
Just bought a 2001 Tahoe 5.3L with 95k miles...so far I've replaced the coils, fuel injectors, plugs, wires, synthetic oil change, drained all fluids except for the rear differential. All interior/exterior lights have been swapped out to LED, new black wheels with 33'' Mickey Thompson MTZ's...K&N cold air intake etc.
The Tahoe is running just as good as my other brand new truck, hopefully I'll get another 10-15 years out of it
*Question.....What brand and Where did you pick up your LED interior lights ? Im considering doing that....i've put 250,000 on my 2001 Yukon XL and loved it. About ready to repaint her and redo interior carpeting : ) Can't see dropping 60+ on a New one, jus sayn.
Cattivo
The Concrete Jungle
I bought everything from super bright led's
2001 Chevrolet Tahoe LED Lights | Super Bright LEDs
I bought black molded interior carpet from stock interiors
Auto Carpet for Car, Truck, Van - Stock Interiors
central4runner
190,*** on my 03 and the trans quit on it he other day, sounds like tin cans in a blender if you put it in reverse but drove forward on my trailer just fine. I talked to the pervious owner (the only other owner) after it happen and he said it had never been serviced or anything. So I thought it lasted a long time and it is also lifted and on 35's since it rolled off the dealership lot brand new. The only other issue I have had is the intake manifold gasket.
MrBalll
West Texas
04 Tahoe at around 156,000. Never put many miles on it since I have a take home work vehicle now. Kind of depressing really.
Conedaddy
