Fuel Gauge Issue - Apparently I Have a 26 Gallon Tank?
mals
Western Mass
So, I was just looking through the forums and saw a thread about the possibility of installing a 37 gallon tank from a 2500 into a Yukon. That peaked my interest because for the past few months that I've owned it the one complaint I've had about my Yukon is the small fuel tank and limited range.
In reading that thread I quickly realized that the standard tank in the Tahoe/Yukon 1500 is 26 gallons. I've been working on the assumption that I had an approximately 16-17 fuel gallon tank based on my observed usage. When I drive my Yukon until the gauge is on empty, and the calculated range is around 50 miles, I fuel up. Looking through my log my fill ups have ranged from 14.5 gallons to 15.6.
I don't think it is the stepper motor in the gauge since the trip computer also thinks the tank is nearly empty. Is this a typical symptom of a bad sending unit? I'm excited to learn that I suddenly have 10 gallons more capacity since I primarily use the Yukon for towing, but I'd like to straighten out the gauge reading so I can confidently use my new extended range.
retiredsparky
I think that your experience is common with these 26 gallon fuel tanks. Most manufacturers deliberately mislead us to make sure there is enough fuel to cool the fuel pump. For some reason, empty on the gauge is about 20 gallons used out of 26. So your gauge is off even more if you are filling up on "E" or close to it and only putting in 15.
A little known part in the fuel tank that affects amount of fuel into the tank is the vent tube. On some vehicles, Ford F-250's for example, the vent tube is extremely low in the tank, so trimming the vent tube allows extra fuel to be pumped into the tank. Your experience might be related to this or not!
mals
mals
Western Mass
I think that your experience is common with these 26 gallon fuel tanks.... For some reason, empty on the gauge is about 20 gallons used out of 26.
Thanks for the ideas. Just to double check I went to fuelly.com and browsed other 2005 Yukon owners fuel logs. Looks like most users largest fill ups are around 22-23 gallons, and a few brave owners push it to 24.
After more research, I am leaning to it being an issue with the fuel pump sending unit. My only hesitation is that most fail and only read full, or empty, or give eradicate readings. When the sender in my Astro failed it read fine for the top of the tank, then eradicate for the bottom half. My Yukon seems to read fine for the fuel range from F to E, just poorly calibrated.
I'd hate to drop the tank, install a new fuel pump only to have the same issue. I guess the worse case I get a new fuel pump out of it and eliminate it as the cause.
mitchn06
So did you do it? I seemingly have the same issue. I think my last fill was 15-16 gallons and I was certain it should have been 20 or more. I'll let you be the guinea pig.
mals
mals
Western Mass
So did you do it?
No, not yet. I've been driving it this way for 6 months, so it's not really a pressing issue. I will likely tackle dropping the tank and replacing the fuel pump in the spring when it will be a little more pleasant to lay on my back in my driveway.
mals
mals
Western Mass
The 2500 has the long wheelbase yeah? I'm not sure it would fit. The fuel tank is a lot longer
Oh, I have no interest in installing a larger tank. I was only referencing that thread since it was what tipped me off that the standard tank size is 26 gallons when I had assumed through experience that it was around 16.
SnowDrifter
Sasquatch Country
Ahh gotcha. Does yours have the information display that tells you how many gallons of fuel you've used?
I generally fill up about 1/3 tank on mine
Edit: Yours is 2005. Don't quote but but I think it does
mals
mals
Western Mass
The only gallon totals I've seen in the information display is in the main vehicle information menu; Total Odometer, Total Engine Hours, Total Gallons Used, and Avg Fuel Economy. My total fuel used is pegged at 9999.99 with an average fuel economy of 12.5. That makes sense to me because 158,000 miles at 12.5 MPG is 12,640 gallons, but seems odd that GM wouldn't see the need to account for more than 10,000 gallons of fuel used over a lifetime.
I've seen no menu items for per tank gallon consumption totals or instantaneous fuel consumption, just projected mile range of tank remaining. If I am missing something obvious in the information center, let me know.
Is there any way to reset the Fuel Total and Average Fuel Economy? I've kept track of that information using Fuelly.com since I purchased the Yukon, but it would be nice to have useful information in the display center.
SnowDrifter
Sasquatch Country
You can reset the gallons used thing. I reset that when I fill up. You should be able to reset them both by pressing and holding the arrow on the lower right of the steering wheel controls
If you have access to a scan tool you can also view the observed/commanded fuel levels
mals
mals
Western Mass
You can reset the gallons used thing.... by pressing and holding the arrow on the lower right of the steering wheel controls
Ha, I really should take a look at the manual that came with this thing. Thanks for the hand holding. It will be interesting to see if the fuel consumption reported matches what I put back into the tank at fill-up.
mitchn06
I tried resetting my odometer, it didn't work. Is there an engine hour thread?
mals
mals
Western Mass
You can reset the gallons used thing. I reset that when I fill up. You should be able to reset them both by pressing and holding the arrow on the lower right of the steering wheel controls.
Filled up this morning, and you were 100% correct. Reset both the gallons used and average MPG. It will be interesting to see if the gallons used for this tank matches my next fill up. Thanks again @SnowDrifter.
Atrus
I know this thread is a month old, but I am running into something similar on the 2004 Yukon I picked up 2 weeks ago.
I picked it up with roughly half a tank. Drove it a couple of days, and had a few other issues creep up (O2's, plugs). As I was diagnosing it in the garage, it was running pig rich and chewing through fuel. Anyway, by the time I got those items buttoned up, it was just above E, no gas light on....darn thing ran bone dry in my garage and wouldn't start.
I threw 2 gallons in it from my lawnmower can and took it up to the gas station...~18 gallons later, the auto shut off on the station pump tripped. I thought that was weird, being that's a 26 gallon tank, but also know those can trip early. Didn't want to push it and pour fuel down the side of it, so I left well enough alone.
Fast forward about a week - during this time, I ran the tank relatively low and threw in some good fuel injector cleaner, and have thrown a couple of gallons into the tank here and there - point is, from what I was tracking, I should have been close to consuming everything I topped off during this period and the 20 gallons I put in from my first fill up. I ASSumed I had 4-6 gallons of usable gas left in the tank, being that it's a 26 gallon tank. I planned on topping off the tank on the way into work this morning....
...except it wouldn't start at all. Filled up my 2 gallon tank again, dumped it in, and she fired right up. Went straight to the gas station 1 mile away and proceeded to put 18 gallons in it....for a total of 20. This time I really tried to push past the first "autostop" on the station pump, and no - it truly was full. The DIC was showing I still had 90+ miles on the tank. I also had no "low gas" light - I know it works, as I've seen it illuminate before I fire up the engine.
So, in summary - my 26 gallon tank seems to only allow me to use 20 gallons. When the truck is dead out of fuel, I can only add 20 gallons in. To me this isn't necessarily just a fuel sender issue. It's almost like the pump is pulling from too high in the tank and can't reach the last 6 gallons. The bummer, too, is that I can't rely on the range meter as the truck seems to be assuming I can get to that last 4-6 gallons when it actuality it runs dry.
mals
mals
Western Mass
Since my last post I replaced the stepper motor on the fuel gauge while I was in the cluster replacing burnt out bulbs hoping it would be a simpler fix than pulling the pump/sending unit. I have also filled the tank twice and reset the fuel gallon meter on both tanks. The stepper motor was not the issue, and I have had opposite results on the DIC measured fuel consumption. One estimated a gallon more fuel consumed then the actual filling, and one almost a gallon less. Both tanks only took 17 gallons from E to full.
I'm fairly certain that if I want to resolve this I am going to have to replace the pump/sending unit. I'm not in a huge hurry to do this, so I'm waiting for warmer weather before I tackle it.
Atrus
A friend did just forward me this...pay attention to post #8, #9, and #11. My thing is, even if it's just a dirty screen...if I am dropping the tank, I am changing the pump. It's a 14 year old vehicle with 122k on it.
http://www.gm-trucks.com/forums/topic/110786-2002-tahoe-wont-start-with-less-than-14-tank/
Drewphil
