DDenali
Nighttime pics of the eagle eye license plate leds on the Yuk
Sent from Dugar's iPhone 7 Plus using Tapatalk
Looks great, you drilled out the hole to fit the light?Nighttime pics of the eagle eye license plate leds on the Yuk![]()
That's how I did it. Driver side blinks normally, while passenger side still flashes fast. Both wires coming out of the resistor are the same color, and there's no pos or neg marked on the body of the resistor itself. Has good connections on both ends. Confusing. I guess this weekend I'll either swap around the wiring or swap resistors. Could be bad. Thx for the help @DDenali , appreciate the input.Tonyrodz this is how I typically wire up the resistors![]()
No problem you may have a bad resistor. I'd like to know your fix for the problem if you don't mindThat's how I did it. Driver side blinks normally, while passenger side still flashes fast. Both wires coming out of the resistor are the same color, and there's no pos or neg marked on the body of the resistor itself. Has good connections on both ends. Confusing. I guess this weekend I'll either swap around the wiring or swap resistors. Could be bad. Thx for the help @DDenali , appreciate the input.![]()
@mmeachem the eagle eye can be placed inside the housing freely so I wedge a washer inside with the eagle eye with the stud sticking out and placed a washer on before tightening it with the supplied with the leds and added just a dab of loctiteLooks great, you drilled out the hole to fit the light?
You got it! Thx again. Hopefully I'll get to it this weekend.No problem you may have a bad resistor. I'd like to know your fix for the problem if you don't mind
An easy way to check if the resistor is working is to check if it gets hot after the signal has been on awhile. No heat means a bad resistor or connection. Compare the heat to the other side.That's how I did it. Driver side blinks normally, while passenger side still flashes fast. Both wires coming out of the resistor are the same color, and there's no pos or neg marked on the body of the resistor itself. Has good connections on both ends. Confusing. I guess this weekend I'll either swap around the wiring or swap resistors. Could be bad. Thx for the help @DDenali , appreciate the input.![]()
Will do. I've seen a few mounted resistors laying against plastic plugs melt them. Are resistors also called switchbacks?An easy way to check if the resistor is working is to check if it gets hot after the signal has been on awhile. No heat means a bad resistor or connection. Compare the heat to the other side.
No, switchbacks are light bulbs that start one color, then turn another color and then back again. I have some LED switchbacks in my front turn signals that stay white until the signal is turned on, then they flash yellow and back to white. So when the signal is on, they alternate yellow to white and when the signal is off they "switch back" to white.Will do. I've seen a few mounted resistors laying against plastic plugs melt them. Are resistors also called switchbacks?
What Red Rocket said lolNo, switchbacks are light bulbs that start one color, then turn another color and then back again. I have some LED switchbacks in my front turn signals that stay white until the signal is turned on, then they flash yellow and back to white. So when the signal is on, they alternate yellow to white and when the signal is off they "switch back" to white.
Where have I been?? Pretty cool!No, switchbacks are light bulbs that start one color, then turn another color and then back again. I have some LED switchbacks in my front turn signals that stay white until the signal is turned on, then they flash yellow and back to white. So when the signal is on, they alternate yellow to white and when the signal is off they "switch back" to white.
Edit: mine are white until the signal is activated, then flash yellow, then switch back to white when the signal is off. Be aware if you use them: I installed them and found out the next morning that the only brake light that worked was the high mounted center one. I ended up needing load resistors in the FRONT marker light circuits. Weird. Anyway now I have all white lights in front which amounts to 5 on each side plus 3 more small individual LED's. (Yes I have full-time DRL's and fogs) Until the signal is on anyway. Probably illegal as hell LOL. The first pic is with lights on, no signal. The next two are signal switchback bulb flashing yellow. Sorry, haven't figured out how to upload videos from my phone.Where have I been?? Pretty cool!
Add your resistors and replace bulb. & on mine i did both of my resistors on the front and both still hyper flashed so what i had to do is open the t-connector back up and squeeze the metal piece real good and checked them again, worked fine ever since @TonyrodzAhhhhh... now I understand what you guys mean by the term "switchbacks".
My question is, how do you wire them up? Piggyback/tap into the turn signal wiring, using resistors?
Keep in mind there is a type 1 or A and a type 2 or B style switchbacksPretty cool!
I went with just yellow flashing because there's another white LED that flashes white in my housings so it alternates between the two, one flashing white and the other yellow.Keep in mind there is a type 1 or A and a type 2 or B style switchbacks
There's a type B or 2. Thats what I have in mine.
Then there's a type A or 1. That is what red rocket has.
It depends in your preference, both are legal. Type A is more like factory like the new style trucks. Type B gives a bit more custom look and more noticeable imo, because it flashes with white and amber instead of only amber and the white is so bright it gets the attention of other drivers.
