Outer Tie Rods
LTV Chaos
So as I've done on past vehicles as the stock parts wear out I upgrade them with sturdier parts, tie rods, ball joints, etc.
My tie rods are going out. Anyone have any recommendations? I've used Moog ball joints on my JK Jeep and those seem to hold up really well.
I have some time off in the next few weeks so plan on doing some work as my schedule allows.
Pete
MichaelSE
2010 2500
Tucson
Moog would be your best bet. I made the mistake of installing Raybestos tie rod ends; within 5,000 miles, one boot split and another was cracked. I replaced the bad one with an ACDelco part, but I'll probably go Moog for both in the future. Makes no sense that GM puts 1/4 ton size tie rods on this 1/2 ton truck.
MichaelSE
2010 2500
Tucson
Yes, so far so good. They only have around 10-12k miles on them though.
TheAutumnWind
Delco MOOG and Raybestos all have varying levels of quality lines available. Their expensive ones are good and their lower end ones are not. Keep that in mind. The R series isn't bad from MOOG per say, but the "Problem Solver" series from MOOG is generally much better for a reasonable cost increase.
jodster1073
I installed Moog problem solvers last fall and have had any issues with them yet.
DesertRat
Will be lifting my tahoe this week and planned to replace tie rods. Are there options I should consider besides Moog Problem Solvers?
I've done a few random searches and they seem to be a general go-to.
probably going to be doing mine soon, I plan on going with the TTX line
JasonW4141
